Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Truck starts fine and idles fine but when given gas after stopping at red lights or stop signs it kills. car parts place said it was the switch behind the ignition switch that controls opening and closing of fuel injectors. Could this be the problem?
    President:
  • 2,468 Answers
Have you replaced the cam position or crankshaft sensor? as these sense timing/rpm of the engine,I do not know about any switch located behind the ignition switch,all of these features are controlled by the e.c.m. ,unless the key switch is that erratic and loses power on a bump and shuts off power to the e.c.m.,but no switch as you describe behind the ignition switch
Posted on Apr 29, 2010
1990 thunderbird cranks up fine but when shift into drive or reverse car shuts off like turning switch off no jerking or anything engine just stops immediately
What happens if you give it a little gas ? Hold the RPM's up , will it keep running then ? How does it Idle , smooth or ruff ? Does the idle seam low ?
Mar 23, 2015 | 1990 Ford Thunderbird
What causes my 1993 Nissan altima to studder or idle rough at red light or stopped
-It could be miss fire,bad coil, air leak, injector or spark plug and plug wire. It's hard to tell at this moment.
-First able you needed to check all above to determine which part is bad.
Good luck
Mai
Aug 13, 2014 | 1993 Nissan Altima
When idleing at a complete stop it dies
Check air cleaner. put some Lucas injector cleaner in the gas tank or a product called mystery oil. Also at night with all the lights off open the hood and watch to see if their is any sparking between spark plug wires.
Feb 23, 2013 | 1999 Ford Ranger SuperCab
The car hesitates when idling or stopped at light/ stop sign, and the rpm drops to zero then goes back up.
The battery was a red herring - it would not have anything to do with the problem.
Faulty spark plugs could cause a miss but probably not make the engine stall.
What you described is a classic example of a faulty idle air control valve or a dirty throttle body. The computer controls idle speed by regulating how much air enters the intake. It opens the control valve to raise idle speed when necessary.
I would check the control valve and the throttle body.
Sep 27, 2012 | 2003 Nissan Altima
2002 Pontiac gran prix engine stall while stopping, then it will restart but runs really rough like its misfiring, but then whn givin any gas or shifted from park or neutral it dies again.
Please include engine and mileage to help with answers. There is a sensor in the tube connecting the air box to the throttle body. Map, mass air flow sensor. It is delicate and pricey. The auto parts has a aerosol can of cleaner for about 8$ designed to clean this part. Carefully remove it from the tube housing and spray it off with the cleaner. This cleaner will attack the plentum and tube melting it causing air leaks if you use it in the tube. On a 3800 If you have coolant leaks or seeping check the plenum it may need to be replaced if it has not already been. They have a new style that is reinforced. This should smooth out the idle and clear up stalling if it's dirty. Air leaks can also cause an unstable idle and stalling at stop signs. Anti freeze can turn corrosive and should be changed. I change mine about every 3 or 4 years. Make sure if your engine contains aluminum parts ( block or heads) that you use the correct antifreeze when refilling or adding to existing levels. Green or orange. Read the label to make shure the product is correct for your car.
May 23, 2017 | 2002 Pontiac Grand Prix
When the truck idles the engine stops running
Does it feel as if the vehicle is not "down shifting" into low gear when you approach the stoplight? If so, then the torque converter "lock up" for OVERDRIVE may not disengaging so the vehicle is stuck in high gear and it will kill the motor. If you switch to park and it starts right back up that might be the problem. A temporary fix is to disconnect a wire from the lock-up torque converter switch, but overdrive won't work and you wouldn't want to do a lot of highway driving until you replace the lock-up switch.
Jul 25, 2010 | 2002 Nissan Frontier Crew Cab
Same problem
Is the clutch properly adjusted?
Oct 09, 2009 | 2003 Chevrolet Cavalier
Engine stalls at stop lights and stop signs
check the fuel regulator,while running unplug the red vacumn hose and if gas squirts out the hole,then it is bad,if not then possibly plugged catalytic converters,drive it on the highway if you can, and stop and look underneath at it and if it looks red,then replace them.Check to see if its overheating,usually a really hot hood tells the story.
Aug 16, 2008 | 1993 Ford Bronco
Why does my car vibrate and noisy at red light and stop sign
Maybe it's the transmission itself. check it.
Jun 17, 2008 | 2002 Kia Rio
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
64 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
