Question about Zanussi 24 in. DE6744S Free-standing Dishwasher
My Zanussi Diswasher model DE 6744s intermitantly gets stuck on a drain cycle following a wash. It will stay like this indefinatley until the power is turned off for a while. It will then continue to work again
    Problem Solver:
  • 18 Answers
I have this problem at the moment and I have just purchased a new Drain Pump, I will let you know how I get on.
Posted on Aug 03, 2010
When I switch machine on it is stuck on drain mode
most probably the solenoid valve that controls the draining is stuck and the water has not drained from the previous cycle or so the machine thinks.
You need a replacement of solenoid valve.
Feb 22, 2015 | Zanussi Washing Machines
Zanussi diswasher ZDI6053N does not finish its cycle.It has to be turned off manually
Your dishwasher is a sophisticated device that registered most failures. The End of cycle LED flashes if there are alarms memorized. So, count how many times the End of cycle LED flashes.
For example:
One flash - i10, the problem with water intake
Two flashes - i20, a problem wit drain water
Three flashes - i30, activated anti-flooding device
..... and so on
Dado
Sep 01, 2014 | Zanussi Dishwashers
I have a Zanussi Aquacycle 1000. It is taking in water and draining but the drum does not rotate both during wash cycle and spin cycle. Urgent help needed as we have people staying from England and NO wash...
Hi.
If the machine is filling up, then cycling and draining, the problem is usually the belt. The belt is reached disassembling the appliance . If the belt is OK the problem is usually the motor or the motor control unit, which is a sealed electronic module connected to motor and to control board and located inside the washer. If the motor has volts and does not turn, then the motor must be replaced. In some less common case the control module itself may be responsible. Motor assembly and belt are located at the back of the drum and get accessed disassembling top and back of the washing machine.
If the machine does not go through the cycle, but it starts draining from start, then the problem is overfill detected. In that case check the drain system, the drain hose, the inlet valve and the pressure switch.
Regards.
Ginko
Aug 29, 2011 | Zanussi FJS1225W Front Load Washer
Water remains in diswasher
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Aug 13, 2009 | Whirlpool Dishwashers
Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
Washer dryer sticks on j cycle does not spin or drain
check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Aug 21, 2008 | Zanussi W1242W Front Load Washer
The dishwasher does not drain water
I had the same problem after a year of use. All the cycle sounded good except for the drain. I disconnected the drain hose with all turned off and only a small amount of water came out ( the inside pan was full ) I then stuck it to my mouth ( gross ) and nothing but back pressure. Another great heave and POW a wad of grease came out. In short by wife poured some fresh stock down the drain which backed into the drain pipe and cooled. Done.
Jul 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Zanussi 24 in. DE6744S Free-standing Dishwasher Logo
212 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
