What gas with 6D48 compressor - Heating & Cooling
    Brigadier General:
  • 3,917 Answers
Please find the details of the gas used in your type of AC.
http://www.airconditioning-systems.com/air-conditioner-refrigerant.html
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 29, 2010
I need a manual (Maintenance) for a Pulman Model 79/10L 440litre compressor. Piston type 7.5KW 1034KPa
cant find reference to pullman piston compressor
try contact us
on pulford site and see if they have a manual download
Piston Air Compressors for Sale Pulford Air gas
Jul 04, 2016 | Air Tools & Compressors
How can I adjust the torque settings?
PDF]SD Compressor Service Guide - Sanden
www.sanden.com/productlibrary/manuals/sd_service_guide_rev_2.pdf
6.6.2 Suction Gas Condition. 6.6.3 Ambient ... Internal compressor pressure can be relieved by removing shipping caps ... Never leave PAG oil exposed to air for a prolonged time. Tightly ..... Place rotor pulley shaft protector (Puller set) over the exposed shaft. 4. ... Replace retaining nut and torque to specification. 1/2-20: 20- ...
Speedaire Air Compressors - About Air Compressors
www.about-air-compressors.com/speedaire.html
when i try to start my gas compressor it backfires why 5.5 speedaire by dayton, serial ... cant find cylinder head torque specs for 35w347 need the torque specs to properly break .... I also need to know how to change the oil on the 1z943b motor ...
[PDF]80 Gallon Industrial Air Compressor - Mi-T-M Corporation
Dec 08, 2015 | Air Tools & Compressors
The compresser making a gas noise
Your compressor may have a internal leak caused by a bad high side valve. If the box is not cooling well and the compressor is very hot you may need a new compressor.
Feb 26, 2014 | Randell Refrigerators
Freezer not making ice
Must start from either a faulty compressor or a gas leak. So put off fridge to cool off then switch on , If there is no cooling in about 2 hours, the compressor or the gas pumping is down provided there is gas in the system. So if the compressor is working warm, please take help to get the compressor pumping or the gas checked so as to confirm. Then estimate and decide.
Aug 31, 2010 | Hoover Refrigerators
Hitachi Gas Air Compressor just stops running
The problem that you describe could be fuel lock due to failure of vent system in gas cap. Easy to check; leave gas cap loose run engine as normal. If problem gone, replace cap with new vented cap. The newer gas caps (California caps) have much smaller vent holes that seem to clog when moving the compressor at too steep of angle causing gas to enter cap choking vent. Temp fix would be to cut small piece from rubber gasket large enough to let air to enter tank. Good luck with your repair.
Jun 29, 2010 | Hitachi EC2510E 5.5hp Gas Air Compressor
Can i use a impact wrench with my hitachi ec2510e gas air compressor
Yes, but it may drain your air supply quickly and you might have to take little breaks and wait for it to fill up again.
Feb 04, 2010 | Hitachi EC2510E 5.5hp Gas Air Compressor
How to fix compressor air gas 55 hp dewalt it
that is probably the top end for this machine. If not sure, visit the web site of the manufacturer.
Oct 10, 2009 | Dewalt 5.5HP 8GAL Gas Wheeled Portable...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
