Question about Husqvarna YTH21K46 (46") 21HP Lawn Tractor 960 43 0085
Disconnecting/bypassing the seat safety switch so that getting off will not shut the motor off. Husqvarna lawn tractor YTH21K46.
I want to disconnect the seat shut off switch on my Husqavna 25 hp lawn tractor
Posted on Oct 20, 2010
I have a Husqvarna YTH21K46. What would cut the fire to my anti after fire solenoid ?
Any one of the safety switches that shut off the tractor will also shut off the voltage to the fuel solenoid. On my mower it is getting out of the seat without turning on the parking brake and of course turning the key off. If the solenoid did not shut off when the engine was shut down it could backfire from the red hot carbon on the head and piston and possibly break a connecting rod . I wish the manufacturers could have put a L E D light panel on the dash to tell us witch safety switch was not happy.
Jul 14, 2016 | Husqvarna Garden
How do I bypass the seat safety switch on a 5424 Husqvarna zero turn mower?
ether unplug it if wont start then jump the wire pigtail with a wire you can bypass both switch like this
Sep 16, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
How do I bypass the reverse kill switch on my Husquavarna YTH26V54 lawn tractor?
On my LGT2654, once you turn the ignition on, you turn the key back to the left one "click" to go in reverse without killing the motor.
Aug 15, 2013 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
I have an 2004 husqvarna yth2148 that starts fine. when i take my foot off the break/clutch it shuts off. i checked the sensor under th eseat and its fine. what could be the problem
all the safety switches tie into a central relay which keeps you from spinning the deck and/or starting the engine unless everything is copacetic. start by replacing that relay as it sounds like you have a problem at that point.
Aug 07, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Husqvarna Riding Lawn Mower 46 Cut model #454140010G MOWER will not ingadge
I can not say this enough, check the safety switches. There should be one on the seat, the clutch /brake pedal and /or the equipment pto switch. Also, check the wires running to these switches. They tend to move and vibrate as you mow and a worn spot in the wires can cause a short, resulting in the mower not starting.
Good Luck!!!
Jul 17, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Want to disconnect the auto shut off when you get out of the seat
Warning: Not a safe idea to disable a safety switch.
If you really want to do it under the seat is a little round switch with two wires under it. If this switch is normally open then cut the wires and cap or use electrical tape to seal the ends. Then test to see if works. If not working then the switch is a normally shut and wires have to be stripped of the last inch of insulation and twisted together, capped and taped. Test to verify.
If really helpful, please rate.
Jul 16, 2011 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Seems there is no power past the safety seat switch. Can I bypass the switch? Key will not click when turned. Thought it was the selenoid, but have tried screwdriver across selenoid, and the mower will...
You can put a fuse or a wire jumping across the safety switch under the seat. This is the most common fix you will find for a faulty safety switch. Do NOT do this if children will be around you while you mow or if you let a younger person drive the tractor! That could result in death or serious injury if they got off of the mower while the unit was still in motion.
Mar 27, 2011 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Husqvarna YTH21K46 (46") 21HP Lawn Tractor  960 43 0085 Logo
1,686 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
