Touchpad won't work or enable
The fn+f9 key on the keyboard doesn't seem to show up and my touchpad will not enable. I have a external wireless mouse and they both worked just fine till a week ago.
    President:
  • 1,469 Answers
you are pressing the wrong key that's why.
Use this: Fn+F7, and start enjoying the laptop.
Have a nice day.
Posted on Apr 29, 2010
Dell inspiron n5030....touchpad not working..not showing in device man..have d/l drivers,incl synaptics.mouse device settings box emtpy.enable/disable greyed out.
Are you certain that the touchpad wasn't disabled accidentally from the Fn key? There are secondary features assigned to each of the Function (F1-F12) keys, usually in BLUE. On of them is to disable/enable the touchpad (toggle-type function, do it one time to disable, the next to enable). You press and hold the "Fn" key (next to the Windows key at bottom let of keyboard, then press the associated Function Key.
Dec 10, 2015 | Computers & Internet
I can't click on anything on my home screen. Gateway N522 series. Won't tab or do anything. Helpppp!!!
Try ensuring that the touchpad hasn't been accidentally disabled (Hold down the '[fn]' key and press the F6 key on your keyboard to toggle the touchpad(mouse) to be enabled or disabled.
Have you tried using an external keyboard and mouse?
If the external keyboard and mouse work then we know it is something to do with the built in keyboard and touchpad on your laptop (likely - but not positively a hardware issue). If it does not work then we know that the issue is likely (but again not positively) software based.
Jan 20, 2015 | O4Jelectronicswarehousecom Wireless N...
How to fix frozen Asus mouse?
Press and hold down the "Fn" key on the laptop keyboard; on most laptops, it is located between the "Ctrl" and "Alt" keys.
Press the "F9" key once, then release the "Fn" key.
This shortcut disables or enables the touchpad if you ever want to add a wireless or USB mouse
Oct 09, 2014 | Computers & Internet
My mother just gave me a toshiba laptop and she had a wireless mouse for it before. I do not have the mouse on it now and the mouse pad is not working. How do I restore it to the original setting?
Hi parothead91...
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 05, 2011 | Toshiba Computers & Internet
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
Touch pad does not work
  1. Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
  2. Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touchpad, which is to control the touchpad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
  3. Now hold down the Fn key and the F10 key to enable the touchpad, in this example, the Toshiba laptops. You press them again to disable it
  4. If none of the above works, plug in an USB mouse, then check into the Control Panel -> touchpad or mouse configurations. Also, check Device Manager if the touchpad driver is installed and working
Good Luck!
Sep 28, 2010 | Computers & Internet
Where is the FN button?
Fn key function key it is located on the left corner and between CTRL and ALT key on the keyboard.
It is used to do some function like disable touchpad Fn+F9 Toggle screen Fn +F5to external display from laptop screen.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
How do you unlock the mouse touch pad?
5. Go to http://support.toshiba.com there click on Downloads.. select your computer.. Product=Portable, Family=Satellite, Model=M35X-S149.. then click on "GO" button on the right.. Again in the next page that comes up click on "Downloads"..
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else.
Thanks for using fixya...
Sep 15, 2009 | HP Compaq nc6000 Notebook
My mouse button is lock how do i unlock it
5.Install Drivers
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else. Thanks, CF
Jun 25, 2009 | Computers & Internet
Touchpad is not working - TOSHIBA Satellite A135-2386
Hey there... :D
Could you try the Fn+F9 Key to Disable/Enable your touchpad mouse?
Because just now i've experiencing the same problem as you guys... and turns out I can make my touchpad working just by pressing the Fn+F9 key.
Note: if your Fn key is not working try installing Toshiba utilities for A135 called FlashCard, run the program and there will be a dropdown menu at the upperside of your screen...
then click on F9 >> and choose Enable.... Thats It... :)
I hope it also solved your problem... :D
Mar 19, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
