Question about LG LRSC-26922 Side by Side Refrigerator
New fridge wont dispense ice?
Is there a specific way to turn the ice maker one, we just got fridge today and have the ice maker button in ice unit to one and still no ice>> am I missing something?
  • 1,998 Answers
The ice maker has to reach 30 degrees for it to start working feell inside the icemaker to make sure your getting water
Posted on Apr 30, 2010
Samsung Model RF28K9070SR/AA water dispenser not working, water line & filter OK
while pushing button see if voltage to water solenoid if ok bad solenoid if no voltage check switch
Jun 11, 2018 | Samsung Refrigerators
My new refrigerator's ice maker and water dispenser doesnt work
Since this is a brand new unit, I wouldn't waste the time or money troubleshooting it yourself; contact the place you purchased it from and exchange it.
Jul 14, 2008 | LG LSC26905TT Side by Side Refrigerator
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
We replaced the ice maker in our Samsung refrigerator and now we cannot get the water to dispense once we cut the water back on. What do we need to check?
By your question, you are saying you are not receiving water from the water dispenser. Make sure the electrical connector you disconnected when making the ice maker repair is securely re-seated. If you removed the door to make this repair, there is also a connector at the top of the door make sure it is also seated. The only other connection for water or ice delivery is at the water inlet at bottom rear of fridge. There are two relays at the water inlet, one for water, one for ice. If these were disturbed recheck that they were reconnected. Of course these checks should be performed with the power cord disconnected to prevent shock. Once all is checked, plug fridge back in. When dispensing water you should hear a solid clunk as the relay engages. As for the ice dispenser you will only hear the clunk as it requires water to fill the tray. Just remember to allow for two complete cycles (fill - freeze - dump) before receiving full cubes. Oh, by all means don't forget to make sure the Ice bucket full lever (Usually a thick wire) running the length of the bucket Is in the down (empty) position. If it is up, this turns off the ice maker indicating the bucket is full. New ice maker units usually come packaged with the (bailer wire) in the up (off) position.
Hope this info helps!
Dec 28, 2014 | Samsung RS2630SH Side by Side Refrigerator
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
How long does it take to make ice on a new fridge. i have a new samsung 29 cubic ft. and no water is being put into the ice maker after 16 hrs of operation. the water dispenser works.
You should have ice by now.there should be a reset button the ice maker try and hold it till you see the ice maker advance. also make sure that ice maker is turned on.If these steps do not correct it set it up for service since it is new.
Dec 04, 2010 | Samsung RS2534 Side by Side Refrigerator
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Water won't dispense from side by side fridge
check for water at bottom of door going in, if there water line in door or tank in door freezing. only fix to replace door. ck with dealer to get fixed under warranty
Jun 11, 2008 | Refrigerators
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
LG LRSC-26922 Side by Side Refrigerator Logo
180 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
