Question about Samsung SyncMaster 932B LCD Monitor
I rebooted my PC and now screen is darker and my colors are off
I have another monitor which is an IBM 9511-AG1, so I hooked it up to my PC and the screen is not dark like the Samsung SyncMaster 932B and the colors are fine. So it does not appear to be a card in my PC, rather the problem seems to be with the Samsung SyncMaster 932B. Has my SamSung SyncMaster 932B monitor gone bad?
    President:
  • 1,561 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Is the power button on while the screen is dark? If yes, it means your monitor has gone bad and the problem could be that the picture board of your monitor is bad that is why it is not displaying anything because another monitor works fine with you PC.
It means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on Apr 29, 2010
  • 560 Answers
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Dark's too dark, Brights to bright?
Monitor Blank hanya dengan warna putih di monitor. bagaimana cara pengatasannya?
Oct 04, 2013 | Sceptre Computers & Internet
Monitor is broken would like to hook up a desktop monitor
Does that monitor work on another computer?..if yes,then try uninstalling your display adapter,loacated in devices manager,reboot your system and windows will reload the drivers.Make sure you have the monitor plugged in when you do this.You may also want to try setting your windows color resolution to 800x600(medium),as the monitor may not handle higher resolution...good luck..please let me know if that works:)
Apr 11, 2010 | ASUS Eee PC 900 Notebook
After a short power outage (2 minutes max) my monitor ( acer al1711)cannot display green. Is the problem the monitor or the drivers?
It sounds like a surge may have damaged the monitor. Try rebooting your system, and if that doesn't work, reinstall the drivers. If the problem persists, the monitor may have been damaged by a power surge and it may have to be serviced/replaced.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Acer AL1711 17" LCD Monitor
Ibm 9513-ag1 flat monitor, get flashing amber light when plugged
hi..check properly the CPU then unplug the monitor and see the message (Signal out of Range) if you see this message from your monitor so its working,so the problem is on the CPU.if the CPU not working remove all the memory then make a clean and video card..thanks and good luck..have a nice day..^_^
May 19, 2009 | Computers & Internet
Ibm 9513-ag1 flat monitor broken switch
I have the same monitor. I had the same problem you have. I couldn't find the correct replacement part so I improvised. The plastic part you refered to just activates a micro switch on the circuit board. In my case the micro switch worked just fine so I used 5 plastic buttons off of some ball point pens as a replacement. I took the monitor out of its plastic case and drilled holes in the front bezel directly over each of the 5 micro switches. I then put the buttons from the ball point pens in holes. So now the push buttons from the ball point pens act as a substitute for the broken part. I hope this helps.
Apr 20, 2009 | ViewSonic VA721 17" LCD Monitor
Laptop doesn't see the monitor i attach to it
1st off there is a Fn key, I think Fn + F5? to turn the monitor on. It is a toggle button that toggles between only the monitor or monitor and Laptop screen both or just the laptop screen.
I hope that can help, if not, please tell me what you have tried. As in, does the monitor work on another PC/Laptop?
G'luck
Oct 24, 2008 | IBM ThinkVision L170 17" LCD Monitor
IBM 9513 DWO
Dont know if you ever got an answer for this question but no the 9513 will only accept DVI input. You cannot change it to accept analogue.
You can test the monitor by using a HMDI to DVI input if you have satellite or cable box with a HMDI output.
E
Dec 08, 2007 | ViewSonic VA721 17" LCD Monitor
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
Samsung SyncMaster 932B LCD Monitor Logo
272 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
