Question about Kenmore 63942 Dryer
No heat Do I need element? how much? how hard to replace?
  • 273 Answers
WITH THE POWER OFF check:
Thermal fuse (should read zero ohms on an ohmmeter).
Thermostat (yours has a combination type, both terminals opposite of each other should read zero ohms.
Heating element. You will probably see broken coils if this is bad.
This is not difficult to repair, but requires disassembling of dryer front, removal of drum and belt, an ohmmeter and screwdrivers, and small socket wrench set.
See this:
http://www.applianceaid.com/wpdryer_how-to.html
and prices:
http://www.repairclinic.com/Kenmore-Dryer-Parts?s=b6a8c244
Posted on Apr 29, 2010
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
Dishwasher is not heating water and wont dry dishes.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element for mineral deposit on it, clean the deposits using a soft brush and a cleaning solution (Don't scrub the element hard). If this doesn't resolves the issue then remove the panel and examine all the wiring connections to the heating element. Now, use a multimeter and check for the resistance reading (ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Dishwashers
Dryer wonT heat, but drum turn
You need a heating element replaced. It is not hard to fix, the heating element should only cost you about $20.00 and for the labor it might cost you $45.00 for the repair man to fix it. A total of about$65.00 maybe even less.
wvrain2006
Sep 29, 2010 | Dryers
I hav e an ADG7450.It will wash at 40 or 50 degrees but not at higher temperatures.Why?
Hi
Thanks
Daniel
Aug 20, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Dishwasher is running through cycles ok but water is not heating so only cold cycles.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element formineral deposit on it, clean the deposits using a soft brush and a cleaning solution(Don't scrub the elemnt hard). If this doesn't resolves the issue then remove the panel and examine all the wirin connections to the heating element. Now, use a multimeter and check for the resistance reading(ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue.
Thanks
Daniel
Aug 07, 2010 | Microwave Ovens
NOT HEATING
have you checked the heating element?
May 27, 2009 | Dryers
Hotpoint dwt 10 dishwasher - the dishwasher tablet is not dissolving and remains in the bottom of the dishwasher after running a load therefore dishes arent cleaned!
I know it sounds strange, but many times when detergent dissolve, a failed heating element is to blame. The detergent needs that water to be hot to dissolve and activate the detergent.
Recommend you check the heating element for obvious damage/failure. When you run the full cycle, does the heating element get hot? If not, replacing it is not as hard as it appears. Post back here with further questions, OK?
If the heating element _is_ working, the other possibility is a failing wash pump motor, but depending on the age of your dishwasher, replacing
May 03, 2009 | Dishwashers
Heating element
You can get to it threwthe back panel with a 1/4 in socket driver.Take the panel off and you can see the element,not hard to replace.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 15, 2009 | Kenmore 63942 Dryer
Not drying no heat.
be element are thermo fuse on element no easy to change remove 2 screws on door hinge 2 screws on the ather side frount comes off there the element
Feb 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is not heating well
run for one cycle with the hose disconnected from wall. if it dreis faster then you have a restriction in the wall or ta the screen or flapper outside
Feb 17, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore 63942 Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
