Question about Fuji FinePix Z1 Digital Camera
Cradle I have a z3 but I assume the cradle is the same. My dog destroyed the cradle-- I charge the battery externally --what kind of cable can I use to connect the camera directly to the computer. Thanks Joe Schwartz
  • josyd Mar 28, 2008
    Thanks for the help---I was afraid this was the answer I would get.
    President:
  • 423 Answers
I don't believe Fuji has a cable to connect directly from camera to computer. The easiest solution is to obtain a card reader which reads the xD cards. Make sure it has drivers for the "M" and "H" type cards, if that's what you have. Some of the cards are single slot (hard to find for xD), & some are multi-slot, in that they will accept various types of cards.
Posted on Mar 28, 2008
Why does my LS 4278 scanner beep when cradled?
It sounds like the power is dropping along the 15 foot length of the cable. You could try connecting a power supply to the cradle and should not hear those beeps any more. The part number of the power supply is PWRS-14000-253R. All of this assumes you are using the STB4278 or CR0078-SC cradle to connect. If you have a CR0078-P cradle it needs a different power supply.
Apr 30, 2014 | Symbol LS 4278 Barcode Scanner
Cobra Micro Talk PR4750WX.New rechargable batteries will not charge in provided charging cradle.
The original Sanik batteries have a negative side with about ten mm of metal showing on the side. Trim the plastic off your new batteries to match and the cradle charges again.
Dec 11, 2012 | Cobra 22 CHANNEL 2-WAY RADIOS
I have 2 computers both with mx700 mouse and they have worked great for a few years. All of a sudden, both have stopped charging. The green light blinks to say it is charging when in the cradle but within...
I assume you are using usb socket to charge mouse. The voltage on a USB is 5volts , you may have a problem here. It may not be producing the correct voltage. Or you may have a problem with your cradle. I would suggest you see a repair person and get them to look at the USB voltage and the Mouse cradle..
Hope this helps.
Feb 18, 2011 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Camera doesn't seem to accept a charge Camera
Yes. You need a new battery. I would assume the same. Have the battery checked or try charging it in the battery charging cradle overnight.
Dec 13, 2010 | HP Photosmart R727 Digital Camera
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Battery or the camera cradel
Parts or a new cradle are hard to find. I don't think Fuji makes them any more, although, depending on where you live, that country's distribution source may still have stock. What we sell our customers is a small charger which recharges the battery outside of the camera. They are about $10 US and plug into the USB port on any computer.
May 25, 2009 | Fuji FinePix Z3 Digital Camera
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
T-mobile phone Not Charging
to where are you connecting the charger?
how old is the charger? maybe the cable its broken in the inside... this usually happens at the ends of the cables or if there is a little bump somewhere..
try connecting them and play with them by moving them a little at the ends.... so there will be better a contact..
Dec 11, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Fuji FinePix Z1 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
