Question about Coleman Powermate Premium Plus 6250W Portable Generator
Engine runs but no out put on generating side
  • 5,603 Answers
Seach google for methods to "flash" the field. There are different methods depending if it is a brushless generator or not.
For brushless type, I have used the method using two series light bulbs between utility power and the generator successfully.
Posted on May 01, 2010
Testimonial: "read your article on flash the field,tried it walla it worked ,supper info, thanks. J.N.Blair .Alberta Canada."
Crafsman 2400 watt generator star ok but only run for 45 sec.& it won't star again the motor is a briggs & stratton 5.0hp
I have a Craftsman Snow Blower with a Briggs & Stratton Engine. I had the same problem. I searched online and read a little bit about this run and stop problem. One solution was to put something over a piece of metal that separates the hot engine part from the other part of the other side of the engine. I used a piece of heat resistant cloth from Lowes in the plumping area where the torches are. It fit and worked. Engine keeps running. I ran it for over an hour last spring prior to storing it.
Nov 01, 2012 | Electrical Supplies
Yamaha ef1000 will start then push choke in and generator stops
clean tank fuel lines air filter and completely clean all carb parts and jets just did mine runs mint now did the same thing i also put in a new spark plug changed the oil a good once over goes a long way just take your time use a good carb cleaner like crc or gumout and check the jets they have small holes on the sides that can clog up hope this helps
May 07, 2012 | Yamaha 1,000 Watt Portable Generator...
I have a coleman 6000. It runs for a whileand when I load it up it trips off.
Make sure the governor is working properly. When you put a load on it the engine should increase in speed slightly. Make sure the engine is running at the correct speed 3600 rpm. Try plugging in an item that draws less power such as a electric drill and see how the generator behaves. Also make sure the engine runs smooth while not under any load. Check the voltage from the outlet to make sure it is putting out 132 volts not under load.
Mar 14, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
Homelite portable generator, LRIE4400...no out put fr unit..has been discontinued fr a few yrs..no parts available..known fr circuit board failure..my dad's , maby 50hr on unit..how can I bypass..or obtain...
If the engine is running but no output from the plugs....the VERY common problem is loss of magnetism in the generator after storage.
With the generator off.........
Look at the side of the generator part.....do you see a small + and - on any terminals?
You may have to take a cover off.
Take a 9 volt battery and momentarily put current from this small battery through these terminals.
Now.....start her up and check for power at the plugs.
This fixes 75% of "no output" after being "stored" generators.
Sep 09, 2009 | Electrical Supplies
Technical Problem
Make sure you have adequate safe space outdoors to run the generator. In order to provide proper ventilation, some generators require 3-5’ distance on all sides of the generator – check your generator manual for specifics.
Aug 27, 2008 | Coleman Powermate 7,000 Watt 13 Hp...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
716 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
