Question about GE 24 in. GSD2220Z Built-in Dishwasher
My GE dishwasher Model # GSD2200GO2WW will not drain. I took it apart cleaned out the food particles that were in the filter basket and checked the hoses... put it all back together... Still won't drain. now what?
  • 1,998 Answers
Did you check the drain pump? if you remove the pump and take an extension cord and cut off the end and add two connetion terminals to the end plug em in then plug them to a wall outlet you willbe able to tellhow well your pump is actually working if your not electricly handy you might be best to call a technician btw use a shop vac to remove the water before you remove the drain pump hope this helps
Posted on Apr 30, 2010
My ge 165D5450p002 has stopped draining the water after a cycle. Is it the pump? how can I check it out
Hello.
Everyone expects their dishwasher will work correctly. They can become nonchalant about it until one day it does not function. Sometimes the dishwasher doesn't drain as expected. Most people immediately call the plumber when their dishwasher doesn't work. There are several things you can try at home before having to pay an expensive service fee.
1 Check the basics. Make sure that the dishwasher has actually finish the cycle. Your dishwasher will not drain until the end of the cycle. Many things may have interrupted the cycle. Check circuit breaker and reset it if appropriate. Also check the fuse. It is possible that you could have tripped a circuit have way through the cycle. Make sure the door is properly closed. Ensure you have chosen a cycle on the dishwasher. It is amazing the problems children could accidentally cause, that are easy fixes.
2 Remove any excess food at the bottom of the dishwasher. The best way to do this is with your hands. Large food particles can block from going into the drain.This is also another extremely easy fix to make your dishwasher to drain.
3 Check to ensure that the hoses are still attached. Use your manual to find where the hoses are. If they are not attached the owner's manual will give you instructions on how the attach the hoses to your specific dishwasher.
4 Attempt to declog the line. Disconnect the hose from under your sink and check to see if there are any clogs. Use a hanger or towels, remove the clog from the hose.
5 Remove the dishwasher basket. Again refer to your owner's manual for specific instructions.Normally you will remove it with a screwdriver. Make sure to work slowly. As you take the basket apart, you will be able to see if it needs to be cleaned. If there is dirt or debris, you can clean the parts with a rag or paper towel. After cleaning these parts, you can replace the basket.
Thanks.
Oct 11, 2011 | GE Dishwashers
Water Laying in bottom of dishwasher
Usually there must be a filter screen in the dishwasher which can cause this to happen. It goes to the drain . If there is accumulation of food particles in the dishwasher filter screen then draining may be obstructed which can cause the water to be stranded at the bottom.
To exactly tell you where the filter is locate and how to clean it please specify the brand and model number of your dishwasher.Usually the filter is located at the back of the dishwasher near the drain. It is usually held in position by means of clips. You can just pop it out.Pour some hot water in the drain and clean the drain line also.
Feb 01, 2011 | GE Dishwashers
Water wont completely drain and leaves gritty film on dishes
Instructions And what
You Need
  • Basic Tools,Rags
  1. Check the basics. Make sure that the dishwasher has actually finish the cycle. Your dishwasher will not drain until the end of the cycle. Many things may have interrupted the cycle. Check circuit breaker and reset it if appropriate. Also check the fuse. It is possible that you could have tripped a circuit have way through the cycle. Make sure the door is properly closed. Ensure you have chosen a cycle on the dishwasher. It is amazing the problems children could accidentally cause, that are easy fixes.
  2. Remove any excess food at the bottom of the dishwasher. The best way to do this is with your hands. Large food particles can block from going into the drain.This is also another extremely easy fix to make your dishwasher to drain.
  3. Check to ensure that the hoses are still attached. Use your manual to find where the hoses are. If they are not attached the owner's manual will give you instructions on how the attach the hoses to your specific dishwasher.
  4. Attempt to declog the line. Disconnect the hose from under your sink and check to see if there are any clogs. Use a hanger or towels, remove the clog from the hose.
  5. Remove the dishwasher basket. Again refer to your owner's manual for specific instructions.Normally you will remove it with a screwdriver. Make sure to work slowly. As you take the basket apart, you will be able to see if it needs to be cleaned. If there is dirt or debris, you can clean the parts with a rag or paper towel. After cleaning these parts, you can replace the basket.
Good luck.
Dec 26, 2010 | GE Nautilus 24" Built-in Dishwasher
Glc4100 water fills but does not drain
You Need
  • Basic Tools,Rags
Good luck.
Dec 26, 2010 | GE GLC4100NWW Dishwasher
The water is not draining from my ge dishwasher
Instructions
  • Basic Tools
  • Rags
  6. Call a plumber. If the dishwasher is still not draining, the problems are a little more complex to fix. It is advisable to call plumber to make your dishwasher drain.
Good luck and thanks for using fixya.
Dec 24, 2010 | GE Dishwashers
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher water draining????
Make sure the odor is coming from the dishwasher.
Pull the bottom basket out and check for food that might be stuck in it. And check for food particles in the bottom of the dishwasher.
Then pour some baking soda into the dish liquid compatment. Run it through a complete cycle. This should deodorize and clean the dishwasher. i hope it helps. Please remember to leave rating.
Jul 19, 2009 | GE 24 in. GLD5860LSS Stainless Still...
Maytag dishwasher filter (?)always clogging
How do I take apart and clean the filter, I've gotten the screws out but to do now?
Dec 22, 2008 | Maytag Dishwashers
I can't find the filter on GE Triton dishwasher to clean it. Also, where do I add the dishwasher salt?
If possible, can you provide the specific model of your dishwasher? ( That would help) also: see attached link to a site that shows pictures of generic GE dishwasher pumps.. at least one view shows a screen on the inlet of the pump however many dishwashers have a screen that traps food particles from draining into the pump and I would look at the loweset point inside the d/w itself for a drain opening. Some mfrs put a screen filter there..Could be more specific if you could provide model numbers though.. Hope this helps..
Aug 24, 2008 | Dishwashers
GE 24 in. GSD2220Z Built-in Dishwasher Logo
496 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
