Question about GE Profile PFSF6PK Bottom Freezer French Door Refrigerator
Ice maker performing poorly only makes 1 or 2 loads per day
  • 1,998 Answers
Check to see if the line coming into the icemaker is frozen nor has ice building up in it if your getting water to the ice maker but its taking to long to drop them then replace the icemaker
Posted on Apr 30, 2010
Every 20 seconds it makes a loud noise like a pump being activated
Sounds like the compressor trying to start. Is it making any ice?
Apr 05, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
DC33 PA 1A
If the machines ice storage capacity is 26 lb per a day then that is all it will make in a 24 hr day Now this depends on water temp entering the machine, the ambient temperature around the machine and the condenser coil and fan is not dirty. Now the machine is capable of making 33 lb of ice in a 24 hour day but the storage bin capacity is only 26 lb if you don't remove any ice it will make only around 26 lb and shut off until it melts and causes the ice maker head to start.
Nov 26, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Hoshisaki makes ice to slow
not sure what "too slow" is to you. Hoshi machines are designed to make more ice per batch but less batches per day. It is not unusual for a batch to take 25-35 minutes for one batch. The 1600 makes a lot of ice per batch. Look for some obvious things. If air cooled condenser, be sure it is clean. Make sure the water to the machine is not Hot water. It is not unusual to get Hot water feedback in a restaurant environment. Check for a leaking water valve. A sticking float can also cause long freeze cycles. Start with that and let me know if I can be of any further help,.
Jun 04, 2012 | Hoshizaki KM-1600S Stackable Crescent...
Samsung refrigerator rf26v ice maker
Check the condenser is clean and clear. Remove all fluff, dust or dirt from under and behind the unit
Apr 23, 2012 | Samsung RF26VAB (25.5 cu. ft.)...
The freezer isn't making alot of ice. Can the hose behind the ice maker freeze?
Hi and welcome to FixYa, I am Kelly.
When a refrigerator slows down ice production it is usually the result of poor air-flow through the evaporator coils. The poor air-flow is due to ice build up on the evaporator coils. The ice build up happens because the unit is not defrosting properly or the evaporator fan is not running at full speed.
To answer your question "Can an Ice-maker tube freeze?" Yes, they can and do freeze but when they do freeze that is caused by a defective inlet water valve that is leaking water by when it is supposed to be shut off. It can freeze if some one set the temp control to MAX cold. Additionally when they do freeze and the Ice-maker cycles the plastic hose on the back of the unit pops out of the ice maker tube and each cycle starts porting ice maker fill water on the floor.
This may sound odd.. but. Perform a manual defrost by removing the freezer contents and directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess so do not leave it unattended) The return the unit to normal service and after 8 hours start watching the amount of ice produced. (Should be normal for 2 days!) If after 2 days the ice production slows again you have an automatic defrosting problem that is causing the ice build up on the evaporator coils.
If you need any more assistance please include your complete model number in any future responses.
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Slow Ice maker
How much ice does it make per day?
There are several things that affect ice making capability, such as -
1) How often the doors are opened
2) Leaky door gaskets
3) Bad ice mold thermostat
4) Light in refrigerator does not go off when doors are closed (easy to test).
Jan 23, 2009 | Frigidaire FRT21H8 Top Freezer...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
GE Profile PFSF6PK Bottom Freezer French Door Refrigerator Logo
170 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
