Question about Toshiba Satellite (K000004080) Motherboard
I have a problem with my toshiba satellite A300D 15N. It is not able to start with or without battery. Morever, the AC power supply led never lights. I tried to remove the battery and press the start button for a few minutes but it never manages to start when I plugged the ac power supply. I have no more idea to process. May be removing the bios cell battery for a while ... May be a power supply fuse. In order to test these solution i need a motherboard diagram but impossible to find it. Do you have solutions ???
  • christophe_f May 01, 2010
    I'm sorry but I don't understand your answer. My laptop is toshiba, and you advices me to get a dell power supply.
    How it is possible to check that, it is a real power supply problem instead of a short cut due to a motherboard issue ?
    I think about that because from my job i have a fujitsu siemens laptop with a power supply having similar characteristics and the result when i plug it on the toshiba is the same.
    I open the laptop in order to access the power supply connector.
    If i chec my power supply output the result is nominal with 19V. When i plug the power supply to my motherboard i measure less than 1V (using the power button or not does not not change anything).
    What is amazing for me is that , I did not find any fuse or cell battery for bios.
    Anyone can provide me the toshiba A300D motherboard scheme, it would be great. My laptop is no more warrantied for only 3 months and i don t want to change it as it was cool laptop till now (less than 2 yers old).
    thanks a lot..
    Genius:
  • 1,027 Answers
You need a new power supply- get a Dell brand, as they have a special connector, and some 3rd party units will not charge the battery.
Posted on Apr 30, 2010
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Jun 18, 2012 | Toshiba Satellite Computers & Internet
My toshiba satellite l35 wont turn on,,,the light blinks then shuts off ,,,thats all it does
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 17, 2011 | Computers & Internet
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
Toshiba Satellite Blinking battery light
Its certainly power issue..... i have had a similar problem with one other toshiba notebook and it was a dying battery....i suggest you to get a new battery for ur set...
May 05, 2009 | Toshiba Satellite A105 Notebook
Toshiba satellite A135 power on problem
Have you tried starting it with the power supply plugged in?
Jan 08, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba a100 laptop
Definitely try without the battery. These models are known to have a "short" problem, usually with the palm rest, which causes this failure, although it usually is more sporatic, and doesn't happen 100% of the time.
Also, can you remove all but 1 piece of memory.
Good luck, and let us know what happens.
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Oshiba Satellite A55-106
Can be because power supply is not correct supply or give incorrect supply voltage causing battery to drain or not charge fully,battery can be caput aswell, some laptops doesn't start if battery isn't conditioned properly. JJ
Sep 15, 2007 | Toshiba Satellite Pro 6000 Notebook
Toshiba Satellite (K000004080) Motherboard Logo
933 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
