Question about Clarion DX-425 CD Player
Cd stuck in player
How do I get cd out without taking my whole car apart to get to player in dash?
  • rath
    rath Mar 09, 2014
    Clarion DX-425: You cannot pull the stuck CD straight out with pliers/tweezers because it sits on a plastic tray that has 2 plastic tips that keep it in place and blocks the entrance. First, press the DCP Release button to detach the face plate (Control Panel), then look inside the opening with torchlight and you can see 2 black vertical plastic tips that's between the CD and the slot opening. Solution: You have to use any tool to manually push down the 2 plastic tips (do one tip at a time) as you slide a thin cardboard/plastic in between the CD and the plastic tip to create a gap. The CD should be sitting on the cardboard now. Only then you can use tweezer to pull out the CD. FRONT =================== CD VIEW +++++++++++++++++ cardboard (slide in between: under CD but above the 2 plastic tips) OF SLOT _____[]______[]_____ plastic tray with 2 vertical tips
    New Friend:
FRONT ============ CD
VIEW ++++++++++ cardboard (slide in between: under CD but above the 2 plastic tips)
OF SLOT ___[]____[]___ plastic tray with 2 vertical tips
Posted on Mar 09, 2014
    Scholar:
  • 84 Answers
Depending on how its mounted/what type of car you have... detach the face plate and pop off the trip ring, then (if you still have them) the keys that came with the radio along either side of the radio and it should slide right out. if you don't have the "keys" 2 butter knives can do the job in a pinch.
Posted on Apr 29, 2010
How can I get a cd out of my car cd player if it is jammed
In most cases holding the eject button forces the player to eject it. If that wont work then check to see if you can see it in the slot and use a butter knife to assist it out. Other than that, take the whole unit out of the dash and take it apart.
Jun 14, 2014 | Cars & Trucks
A friend forced a cd into the player on my 2003 Silverado. It will not eject or let me put another one in.
negative you will have to remove the radio and reset by unpluging and pluging back the power plug
Jul 13, 2012 | 2004 Chevrolet Silverado 2500HD
2005 mazda 6- Cd player constantly trying to eject and keeps draining the battery
Yes take it out the dash then take it apart and remove the cd player section or just pull the multi plugs out that it connects to teh mother board wwith
Mar 05, 2012 | 2005 Mazda 6
Factory stero
You will need to remove the CD player from the dash and then take it apart to retrieve the CD, then get it repaired the loading mechanism is defective.
Feb 14, 2012 | 2005 Pontiac Grand Prix
I installed my new aftermarket CD player on my 1999 Pontiac Grand AM today but as I was putting into the car, the yellow power wire sparked and it wouldn't work. So I figured I blew out the CD player but...
sounds like you have melted the ill. wire into the 12 volt constant somewhere in the wiring harness. You have a few options you can fix it by tracing down power wire behind the dash seperate the 2 wires and tape them back, but that involves taking out the dash to trace them. You could replace the whole harness which again requires taking apart the whole dash and is expensive, or you could run the power wire down to the constent on your cigerette lighter. Find a wiring diagram or test the wires to see which is which. NOTE: always unhook the battery when you are installing a new stereo because the constants are just that a contant 12 volt feed. but to test the cigerette lighter wires you will need to leave the key off and battery on gound your meter to something and which ever wire gives you voltage is the one you want.
Mar 08, 2010 | Pioneer DEH-2100 CD Player
How do you get in to remove the stereo?
No don't take the whole dash apart there is usually a bunch of screws and you may have to take apart half of the dash.
There is usually some sort of plastic panel that must be removed than a bracket underneath it all to release the stereo sometime's for example fords have special lock key that you must use to remove it
Sep 24, 2009 | 1992 Jeep Cherokee Sport
1996 es 300 lexus cd player wont play says error
For the cd player error.I just fixed mine i had to take the whole unit
out.Take it apart remove the laser and clean it .I'am a Electronics
Tech ( but it's not hard ) use a Q-tip and some 91% Isopropyl Alcohol.
This will help for new cd's.( before even new ones errored out)But old ones, it still error's out.
Because the laser is old and weak.But if you got the time it can't hurt.
good luck
Feb 13, 2009 | 1996 Lexus ES 300
Broken Tape Player
Don't be alarmed too much. Most tape players in vehicles die after 10 years. Mine died in a 20 year old two years ago too. Most likely if the radio is easily removed from the dash go to a dealer or junk yard and find a replacement. Most of the radios of the nineties and up are not easy to take apart and remove just the tape player assembly to replace it. But if it is, check to see if the electric plug wires are snug and plugged in. But your best bet is to just replace the whole unit without trouble.
Sep 07, 2008 | 1997 Ford Explorer AWD
Stuck CD in car stereo
erm Nope. its a strip down
Sorry :(
Mark
Jul 18, 2008 | Car Audio & Video
How to remove
just take out the whole dash kit and then you will be able to take it out
Dec 26, 2007 | Jensen MP5610 CD Player
Clarion DX-425 CD Player Logo
108 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
