Question about Technics SL-1200M3D Turntable
I have a technic sl 1200 m3d with a broken tone arm, which arms are compatible?
    Sergeant:
  • 432 Answers
Use the mk-5 , is the same and most peoplescsay the 1210mk2 will fit also , but mk-5 has the same arm 80 euro second hand and leave the origin live for what it is ..... Don't try to rebuild the technics to a real hifi unit.... I can help you by saying what and how to do, but
origin live sucks at this pricepoint and it ain't scratching anymore and the rewire is not cheap, but fun since i use silver and they are against it since only conducts a bit better, but they let you pay amazing prices for copper, only the difference between normal cable is max 1% compared to ofc and the real clean copper doesn't do a thing and is aimed for liquid oxygen containers and embryo's around -200 degrees celsius.....Bye a new mk-5 arm since there's more available and a nice pair of rca cables, no oyaide nonsence, i tried them for the denon distribitor, hear nothing.
Same for the digital one.
Posted on Aug 16, 2014
  • 189 Answers
HELLO
Have a look at Originlive on the net. They do an armboard which should fit your turntable easily and enable to put a Rega RB250 or RB300 arm on your machine - it will improve audio quality too!
Posted on Apr 30, 2010
Technics SL QD22 buttons stopped working
Hello, looks like you have a control board faulty. there is nothing you can do, only if you get that to your next repair shop.
Nov 22, 2013 | Audio Players & Recorders
My technic 1200 mk2 skips records, i tried other needles and adjusted tone arm. Even tried pennies on cartridge
Ensure that the turntable is sitting as flat as possible and does not allow any external vibration to penetrate.
Also try operating it without a record on it make sure that the plate is turning smoothly without interruption and also does not have any vibration.
Nov 23, 2009 | Technics SL-1200 Turntable
Technics sl 1200 MK2 WEAK SOUND
Regarding the poor sound quality (and possibly the skipping):
check the needle condition, see if exchanging it with a needle (or the entire pickup head) from a working turntable does any good.
Check the pickup connection pins (contacts on the pickup head and on the end of the wires coming through the arm from the unit), see if there is any dirt or oxydation and clean the contacts if necessary, also check for any damage to the wires.
As for the skipping - a heavily worn needle may affect the sound quality and cause skipping as well - if cahnging the needle (or the pickup head) doesn't make a change, try to realign the weight on the tone arm so that the pickup head will become a bit heavier, this could help somewhat (before you actually try to realign the weight, try to put a small coin or a small weight of some kind on the pickup head while it is playing a record, if the skipping goes away, you need to realign the tone arm weight).
This could also be a problem with the tone arm lifting mechanism (may be obstructed by something or damaged so it won't let the tone arm sit properly onto the record and "grab" the groove).
I just mentioned a few things you might want to check, but don't take anything for granted, the problem may as well be elsewhere in the unit.
regards
Triarcuate
Sep 22, 2009 | Technics SL-1200 Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Tone arm trouble i think???
this is a damaged tone arm bearing i had this problem with mine and had no choice other than spending £50 on a new tone arm
Mar 08, 2009 | Technics SL-1210 Turntable
Tone arm is hard to move and when it's placed on a record the needle sticks at on spot on the record. the same needle and record plays fine on other technics 1200 mk5. seems like the arm has resistance in...
You have a bad tone arm. I have the same tables. You need to get it repaired if under warrenty. Or there is a service manaul online you can get from ebay. Service center for our tables is Panasonic.
I had the same problem on mine. But while it is in the shop they recalibarte it
Feb 13, 2008 | Technics SL-1200 Turntable
Arm Looping
ive had this problem djing in front of 700 people...Not good!! i can tell you exactly what it is, the tone arm bearings are being pinched too tight or there is a tiny piece of debris in the bearing race of your tone arm or blatentley your vinyl is scratched lol.... assuming you ve set your stylus correctly and the turntable is level on both axis???? slightly unscrew the tiny screw on top of the tone arm just enough to release the pressure on the bearings inside, but not so much that it wobbles about??? happy mixing
Jan 25, 2008 | Technics SL-1200 Turntable
Tone arm skip back.
You most likely have broken balls,,, lol yes balls bearings are most likely broke you might have to replace your arm.. about 80.00 for the part
Oct 17, 2007 | Technics SL-1200 Turntable
Technic SL1200 M3D
1) This turntable either has bad RCA cables or a faulty tonearm - in either case, none are easy fixes. FYI, If you use Ortofon Concorde series, they are notorious for causing faulty connections with your tonearm, and eventually deteriorate your tonearm over time. So you might want to think about changing them if you get a new tonearm put on. If you use the Technics headshell, you are fine. 2) This turntable definitely needs to have the tonearm replaced. Once the arm comes loose from it's bearings, it's next to impossible to get it back to factory specs, and you will have skipping issues. Both will require professional servicing. Check out www.1200s.com if your in the NYC area.
Sep 07, 2007 | Technics SL-1200M3D Turntable
Technics SL-1200M3D Turntable Logo
145 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
