Question about Canon PIXMA iP1800 InkJet Photo Printer
The paper is going through and it sounds like the printer is ptinting .but nothing on thr paper
  • 4,041 Answers
Hi There
Try this first it may clean up the heads, if not this then it can be the printer driver got a virus or needs reinstaling.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
Why do I keep getting a line in the miidle of pages when I copy ?
It might b toner prob. Plz check the toner if it has any small piece of paper or anything stuck into it. If u find anything thr, remove n try copying. N if thr is nothing thn u might hv to clean the toner and if the line is still thr thn u hv to replace the toner.
Sep 21, 2015 | Office Equipment & Supplies
Paper misfeeding on one side but printer keeps printing with no paper
Look for any foriegn objects or old torn paper from an earlier jam. Something is either obstructing or mis-guiding the paper. If nothing is found, use a can of compressed air to blow thr paper intake area out, then test print again.
If still not solved, use a cottom swan soaked in alcohol to scrub clean the rubber paper pickup roller. Over time it gets slick from paper dust and the paper will notget grabbed evenly, causing it to skew as it's pulled in.
Jul 26, 2011 | Lexmark X2470 All-In-One InkJet Printer
I've got a HP 680C recently fixed, now it has a problem. It pull a paper but it doesn't ptint it out. Tks
Do you have good cartridges in it? Sounds like the ink has dried up or something is wrong with the cartridges
Nov 02, 2009 | HP DeskJet 680c InkJet Printer
Paper Jam, when there isn't a paper jam!
just remove thr paper outer tray and see if there is any part of paper is there.
Sep 08, 2009 | HP Photosmart 3210 Printer
Dotmatricx printing
Each machine has it own printing language (HPCL, HPGL, PostScript, etc.) You must first find out what command language it responds to.
Hope it helps.
Aug 28, 2009 | Epson LX-300 Matrix Printer
I had a paper jam which I cleared, will do test print, nozzle cleaning, etc but will not ptint from the computer or scanner
Check connection of chip to head carriage. For printing, epson main board read ink level counter in chip. It may be have bad connection. Try to use another chip.
Jul 24, 2009 | Epson Stylus Photo R340 InkJet Printer
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
LEXMARK 3400 ALL IN ONE
paper feed pulls to the right and there is no paper jammed and the paper guide is set.
Mar 18, 2008 | Lexmark X3470 All-In-One InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
old marine
old marine
