Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer help... agitator
Hello Dr,
I am having the same problem as described below and was wondering if you could help...
My problem is the top part of the agitator doesn't seem to be spinning correctly. I can twist and twist and it will never tighten. I'm not sure if it's supposed to pop in or something else, but I didn't want to break it.
If you can please help I would appreciate it!!
My email is [email protected].
Thanks,
MichaelG
-------------------------------------------------------------------------------------------------------------Washer fills up w water but agitator won't start. It was starting when I would open & shut the lid. Now it won't at all. Sounds like a sensor problem. How can I reattach the sensor? Where can I find a diagram of the sensor or part number. Top load washer Whirlpool Ultimate Care II SM8525079
Post Solution Work Queue --> Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Best Solution posted on Sep 27, 2007
the dr
Rank: Guru
Rating: 88%, 455 votes
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!) -------------------------------------------------------------------------------------------
Can You help me too!! I have the same problem with My whirlpool! and I'm still finding My way around this Forum!
Posted on Apr 16, 2008
SOURCE:
Wtat is the dr code error?
Hello Aung, I appreciate your post!
Based off what you have described your Electrolux washer is displaying an error code of "DR". The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. You should perform a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Dec 30, 2015 | Electrolux Washing Machines
PAV2300 agitator bolt keeps coming loose
Loctite sounds the order of the day. Don't overtighten once the thread lock is in place and allow to cure before using machine.
Apr 23, 2012 | Maytag PAV2300 Top Load Washer
How to remove the agitator on a GE ProfileWPSR3120W0WW? The utube video (describing a bolt at the bottom) does not describe accurately what we have. Softener dispenser removal only yields a clear plastic...
Your washer is close to the one in the video but as you know not exact..that agitator coupler shown in the video bolts down under the agaitator. To remove your agaitator which locks into teh agaitator as shown just pulls off....so to remove your just grab the bottom of it and pull straight up and off of the agottaor coupler.
GENE
Sep 07, 2011 | GE Profile WPSR3120WWW
Top load fisher paykel 2004, mid cycle of wash alarms won't agitate or drain
Hello - No one can help you if you don't describe the alarms, colours of the lights its position on the display. It could be the drain pump but cannot be sure - need some help here...
May 02, 2011 | Fisher and Paykel GWL11 Top Load Washer
Agitator does not spin clothes during wash and rinse cycle.
Hello , iwill try to help you with your washer problem.. so your washer fills up and when lid is engaged with a screw driver into the lid switch thw washer makes noise like its agitating but is not agitating or spinning sound like your ( coupler has gone bad .. A coupler is kinda like a belt it syncronises the transmision to the motor it is part #285753a around $20.00 dollars on the parts break down it is item number 13 check under the washer for black rubber pieces 10042888-00006.png if you need step by step instructions you can always call me for phone technical support...dr.appliance
Feb 23, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Water is draining very slowly out of the washer and if it takes to long it gives a code of DR
Hi
It seems that something is stuck and you'll have to remove the agitator to clean it. I f this is an old style washer, then it should have a bolt under the cap that must be removed to remove the agitator, then grab hold of the agitator and lift up. If it's a not too old then the agitator just pulls out, remove cap, if no bolt, just grab hold and lift up hard...picture. You can also clean the drain hose as that might be clogged if the agitator is fine. Hope this helps...please post back for further assistance.
Daniel
Jan 10, 2011 | GE Spacemaker WSLP1100D Top Load Washer
I have a maytag MAV5920EWW and i need to know how to get the agitator off as well as the front panel
Hello there:
here isa couple of links below that will show you how to do it ok
I hope that this is very helpful for you
Best regards Michael
  1. [PDF] 16026502 Maytag Amana Top Load Washer 8628k - Adobe PDF - View as html MAV5920EWW. MAV551EEWW. NAV8805EWW. Electronic. Energy Star rated. ... "Agitator/Spinner/Outer Tub/Transmission Removal" procedure. ...www.servicematters.com/maytag_library/docs/16026502.pdf
  2. [PDF] Technical Bulletin 1950k - Adobe PDF - View as html MAV4758AWW, MAV551EEWW, MAV5758EWW, MAV5920EWW, MAVT236AWW, MAVT346AWW, MAVT446AWW, MAVT546EWW ... 4. Remove Agitator by loosening bolt threaded into ...www.servicematters.com/maytag_library/docs/TDL-0086-B.pdf
Nov 22, 2009 | Maytag MAV5920E Top Load Washer
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Dec 03, 2008 | GE WBSR3140DW Top Load Washer
Maytag stack unit washer dryer unit
Not in the way you have described!...LOL. Seriously though, I can only discern that if you have selected the maximum water level available, then you are overlaoding it and need to remove enough items so that when the washer agitates, the clothes will circulate down and around the agitator, reappearing up at the top in different quadrants of the wash tub. This is true with any level you select. Another guideline to help choose the water level is to keep the items at or below the 3 oblong vertical hole slots in the side of the agitator. Then choose small, medium, or large water level.
If that doesn't help, then post me back with a more definitive description of the issue you are experiencing and any negative results you are having concerning the issue..
Good luck Dan!
Thank you for contacting me at Fixya.com
Dave E.(Illeagle)
Nov 28, 2007 | Maytag LSE7806A Top Load Stacked...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
372 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
