Question about LaCie (300740) 160 GB Hard Drive
I have an old La Cie 160gb (maybe 5 years old?) - do you know the specs? rpm, for instance? I need something with 7200. This old one must be 5400, right?
  • 3,866 Answers
Lacie drives have a 5400 RPM on there 160GB line nothing really changed until 500 GB to 1tB at 7200 RPM.
so the answer is 5400 RPM
Hope this helps please do rate and leave feedback.
Posted on Apr 29, 2010
Testimonial: "Incredibly fast and helpful. Thank you"
I have a asus eee pc 900 ha and believe the hard drive is no longer good. Slow boot up (9 minutes is fast) and there is a light clicking sound as it tries to boot or access a program. What specs do I...
Sounds like a hard drive problem to me too. I'd get it replaced ASAP. It is a standard 2.5" SATA drive in the 900 HA. In terms of specs, you'll get better performance with a 7200 RPM drive, but worse battery life. Don't get a hard drive a ton bigger than you need - there's no point. Save yourself some money that way. A 250 or 320GB 7200 RPM drive will certainly work. It takes 4 small screws to remove the current hard drive. The only other thing you need to consider is whether or not you want to image the drive, or just back it up.
My recommendation for a cloning program is Norton's Ghost (which is not free). At the same time, for a situation like this, I wouldn't bother imaging the drive and would just get a fresh install of Windows if possible - that's just me though. If you need any more help don't hesitate to ask! Alex
May 31, 2011 | ASUS (90N804SH021) Hard Drive
I have a Seagate external hard drive model # 9w6044-500. I need to know what kind of drive it has, how many gigs it is and what size disc it uses.
Welcome to Fixya. Here's the specs of the hard drive
MPN: 9w6044-500
Capacity: 160 GB
Interface: USB
Enclosure: External
Spindle Speed: 7200 RPM
Special Features: Vertical or Horizontal Placement
Internal Data Transfer Rate : 464 Mbit/s
External Data Transfer Rate: 60 MBps
Seek Time: 8.5 ms
Buffer Size: 8 MB
Average Latency: 4.17 ms
Interface (Detailed): USB 2.0
Hot Swap: Yes
Platform: PC, Mac
Height: 2.25 in.
Width: 6.5 in.
Depth: 7.13 in.
Weight: 2 lb.
If you have questions please let me know. Thanks for using Fixya.
Mar 13, 2011 | Seagate (9W6044-500) 160 GB Hard Drive
My external La Cie 500Gig HDD has worked well for 3 years or more. Now when I connect it (via USB as aI have always done) ..The following happens: 1 I see the drive usually but not always under "My...
your drive has failed at either the power supply level or internal hard drive level.
First, please verify your power supply. When plugged into the power outlet, it should be silent. A defective power supply will hiss or have a high pitch noise to it. If it is defective, replace it and check if the issue is resolved.
If the power supply is silent, one or both of the internal hard drive is failing. If no data is needed, you can either replace the defective one which you will have to isolate by connecting the internal hard drives to a computer or with another enclosure and running a block scan software like hdTune which is free to download. The other option would be to scavenge the healthy drive and use it in another enclosure or inside the computer directly.
If you need the data and the problem was not the power supply, you will need to contact a data recovery center.
Regards,
Jan 07, 2011 | LaCie Big Disk 500 GB Hard Drive
The hard drive in my HP A1000n Computer crashing and is corrupted. How do I know what type hard drive to buy to replace it?
according to the model you have these are the ones that were built with this computer . One of these is in your computer . Which one of these is your drive ? p/n is on right side
PS591-69001 200GB S-ATA hard drive - 7,200 RPM (Seagate, Quiet)
DK322-69001 80GB IDE hard drive - 7200 RPM
DF283-69001 160GB IDE hard drive - 7200 RPM
please issue positive feedback for me
Oct 19, 2010 | HP Pavilion a1000n (PS567AA) PC Desktop
I need to know what kind of hard drives and other hardware i can use with a HP Compaq D530 Socket 478
HERE shows an overview of the specs for the HP d530 series. Shows IDE type HD's.
Technical Specifications - Hard Drives
7200 rpm SMART III Ultra ATA/100 Hard Drives 40-GB Capacity 40,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 78,165,360 Operating Temperature 41° to 131° F (5° to 55° C) 80-GB Capacity 80,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 156,301,488 Operating Temperature 41° to 131° F (5° to 55° C) 160-GB Capacity 160,000 MB Rotational Speed 7200 RPM Interface Ultra ATA/100 Height 1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including setting) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 320,173,056 Operating Temperature 41° to 131° F (5° to 55°C)
Feb 21, 2010 | Computers & Internet
Need to format without losing saved data
The trick to not losing saved data is to back it up to somewhere else, like an external hard drive.
Nov 07, 2009 | LaCie 160GB USB 2.0, 7200 RPM, 160GB...
Can this take a 7200 RPM HDD?
The only compatibility issue for a hard drive with your laptop is the interface, whether it's IDE/PATA or SATA. Seeing as it's an old laptop, it's probably IDE, and I don't think you'll find many 7200 RPM laptop IDE hard drives. All the 7200 RPM laptop hard drives I know are SATA. So, probably not. If you need more help with your laptop repair, contact me through my website.
Nov 04, 2009 | Toshiba Satellite M35X-S109 Notebook
What kind of case enclosure (3.5) should I buy?
Check out the review on the hard drive case we use in our shop at www.ccl-la.com We have been using these drive cases for a while and have had no complaints, and it works for both IDE and SATA.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 09, 2009 | Western Digital USB 2.0 External Enclosure...
New hard drive choices
Hello, Bob!
Seeing as I am a 6 year veteran of Dell Tech Support, I should be able to help you out, no problem.
One thing that I would like to let you know is this: according to Dell Support Policy, you ARE allowed to put a non-Dell-branded hard drive in your computer. However, if Dell Support deams that this non-Dell hdd has caused another Dell component to fail, they will not replace the defective product. BUT, since it is HIGHLY unlikely that a non-Dell hdd would actually cause any other failure, feel free to purchase a non-Dell hdd. (I often times suggested that customers take this route because unless you're purchasing a refurbished Dell product, you're only paying for the Dell name.)
Anywho...
There really are no limitations to what size hdd you can install in your computer. Of course, a larger hdd will take more time to process information (Basically, there's more surface area to scan when your computer is searching for a specific piece of information.). Your main thing will be determining if you have an IDE hdd or a SATA hdd.
The Dell Tech website CAN be your friend (support.dell.com). From there, you can view original configuration and even available upgrades simply by entering your service tag (Usually found toward the back of your computer, on a black sticker with white text. It should list your service tag, an alpha-numeric value, and express service code, an all-numeric value).
If I were in your position, I would most likely not go over a 160g or 200g hard drive... simply to keep decent performance.
Hope I helped!
Oct 29, 2008 | Dell Dimension 8200 PC Desktop
Open Questions:
LaCie (300740) 160 GB Hard Drive Logo
253 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
