Question about Sharp CV10NH Air Conditioner
Been researching this model, and haven't seen anything about what type of refrigerant it uses. Does it have a compressor and use refrigerant?
    Novelist:
    Champion:
  • 246 Answers
Yes it does have a compressor - I believe this particular unit is a 10000 BTU unit w/compressor and uses R410A refrigerant which is btw a ozone friendly refrigerant.
Posted on May 07, 2010
HELO PLASE TELL ME WHAT IS THE SUITABLE COMPRESSOR FOR MSD2657HEW REFRIGERATOR?
look up replacement using your make and model number of fridge
May 01, 2017 | Refrigerators
What kind of freon does this model refrigerator need
Most all Domestic refrigerators these days use R134 refrigerant such as yours most likely uses. The easiest way to assure what type of refrigerant would be to access the compressor area and look on the side of the compressor. All compressors have a tag showing what type of refrigerant is used in the unit. If you have any further questions or if you need a detailed schematic showing how to access the compressor area message me back your complete model number and I will provide one for you.
Thank you,
Rick
P.s. Never assume a unit uses one type or another types such as R11,R12, and R22 are being phased out due to government regulations on the hazzardous chemicals found in refrigerants such as these. It is always best to check the compressor for the labeling tag.
Jul 01, 2012 | Sub-Zero 561 / F
My whirlpool refrigerater is not cooling properly, the freezer is working but the fan in back turns freely by hand but I haven't seen it actually start by itself
replace fan motor. same thing happened to me but I can't see other end of fan wires.I will have to cut and solder wires for new fan...I have question on how to get that darn relay box off compressor to see where condenser fan wires go!!!
Jan 28, 2012 | Amana ATB1832AR Top Freezer Refrigerator
Since the summer turned to full heat our freezer has stopped working well. its cool in there, most things are still -mostly- frozen but icecream and 'otter pops' wont stay frozen. just vacuumed out...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 19, 2011 | Amana ARB2217CSR Bottom Freezer...
My Whirlpool Imperial refrigerator isn't getting cold enough. I thought I should clean the coils, but there aren't any on the back. I did clean the vent in the front and haven't seen any change...
heatman101
Jul 16, 2011 | Refrigerators
Fan moves slowly ,compressor still hot even with a portable fan blowing on condensor ,but temps are back to normal. What would cause the fan to blow slowly and there is no obsructions
Ralph78yanks,
Your condenser fan (fan motor by compressor) is a variable speed and controlled by a computer board and compressor speed. If the fan motor slows down and the compressor is running in high, the unit can over heat and cause temperature issues in refrigerator sections. GE has a program which can see actual fan RPMs of motor. As I research this incomplete model number (7 possible different models) I see they all use the same fan motor Part# WR60X10209, this is a DC motor. Make sure you fan has not melted also. The heat from the compressor can melt the should or blade when this motor fails. I hope this information helps you..
Jul 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
1993 SL2: What type of refrigerant does the 1993 Saturn sw2 ...
It should be written on your compressor. But I do believe that the saturns switched pretty early. All the 93's I've seen so far have the 132a
May 18, 2010 | 1993 Saturn SL2
Amana side by side Refrigerator model #asd2624hes is not cooling
its most likley the compressor if you wire the compressor independently and get the same sound then you will have to replace it
Sep 22, 2009 | Amana ARS2661B Side by Side Refrigerator
Refrigerator was left on, now does not seen to cool
If you cannot hear the compressor running, the problem may be: Bad compressor, Bad Relay, or if there is no lights or anything in the fridge, it may be the power supply. You can test each device with a multi-meter.
Jun 02, 2009 | GE Refrigerators
Sharp CV10NH Air Conditioner Logo
195 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
