Question about MSI NX7300LE-TD256EH GeForce 7300 LE, (256 MB) PCI Express Graphic Card
Screen resolution of 1920*1080 is not shown as an option when I plug in my 24" monitor. How do I get the card to pump out this res? PC is running XP, the card is reporting fine no issue with the res it does display, except they look terrible on the screen. Nearest res is 1920 *1200. Why doesn't it show a resolution it is certainly capable of showing, the NVIDIA control panel even correctly identifies the monitor make and model !
    President:
  • 524 Answers
GeForce® 9800 GX2
This will be far better than what you are looking for.
Let me know if you have any further questions or concerns.
Thanks.
Posted on Apr 29, 2010
  • justaguy44 Feb 02, 2011
    Is this the most affordable solution? A new video card?
Samsung 244t Monitor display issue
if the monitor will match well with Nvidia GTS8800 graphic card, you need to consider two issue:
1) resolution match from windows display property and moniter manu same one.
2) refresh frequency match from windows display property-->advance-->monitor and monitor manu--> refresh frequency
if two side setting could be all matched that you can use normally
if two side setting could not be matched any above step that you can not use some resolution normally possible.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 29, 2009 | Samsung SyncMaster 244T 24" LCD Monitor
Screen resolution on powerpoint cannot be locked at high res. Changes when connected to my projector. Monitor screen res. also changes everytime the projector is plugged in, In power point display (2nd...
I just checked the specs on your Benq PB 6110, which has a native resolution of 800X600 and will simulate 1280X1024. When you connect it to your computer, the computer goes to 800X600, right? That is the resolution of the BenQ. How high a resolution do you want? THe highest I have seen in projectors is 1024X760, which is not that much higher. Projectors seem to lag behind monitors and Plasma/LCD/LED TVs for resolution. They must have a very small market share therefore low developement.
May 07, 2009 | Microsoft Office PowerPoint Home and...
Monitor not supported
Well the monitor not being support is not the issue. the issue is the video card cannot produce a signal that is supported for the monitor. Its doing this to let you know also to lower your resolution because the monitor will pop if the resolutions is to high. the monitor itself does not matter if you had Vista as lond as the monitor agree with the signal your cool if it don't it will do this. Try lowing the res using another monitor then put the orginal back on and you should be good.
Thanks
Apr 24, 2009 | HP dc7700 PC Desktop
ACER with Dell 24" monitor
If it is a Dell Ultrasharp 2408WFP it can display a max of 1920x1200.
Mirage 3 is integrated graphics I believe and integrated graphics have no business running such HD resolutions such as 1920x1200. It will choke or refuse to do that resolution generally.
Other 24" Monitors can do a max of (1920x1080) which is basically 1080 HD resolution. You need to find which monitor you have, what its max resolution is, and then find what the max resolution is that your SiS Mirage 3 can output.
Mar 19, 2009 | Computers & Internet
My computer monitor loses resolution
try running your graphics card in separate screen mode im thinking you may have it in clone mode and is running both displays at the same res, or if the projector can handle it try running the projector at higher res
Dec 15, 2008 | InFocus LP70+ Multimedia Projector
I reloaded win xp get lowest res. cant get higher res
sounds like you need a driver for you video card go to driver.com
Dec 14, 2008 | HP W1707 LCD Monitor
We can't get our screen resolution back to what it was (1024x768) it changed when a game being played ended. It runs on 800x600 at the moment and everything is too big.
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Aug 05, 2008 | Computers & Internet
Distorted screen
Youre problem is because when a widescreen monitor is fed with a signal that is not ws it stretches the image sideways making people look short and fat. The only way to really fix this is to make sure the graphics card is providing a widescreen resolution to the monitor. In this case the native resolution (the resolution the screen looks best at) is 1680 x 1050 . If you right click ur desktop and go down to properties and settings u want to change the screen resolution to a widescreen res.
Hopefully 1680 x 1050 ... if this is unavailable try 1440 x 900
If you have an nvidia graphics card you can also go to the nvidia control panel and change the resolution attributes. If the widescreen res isnt available u could also try the 'change flat panel scaling' and select the do not scale option.
Please note before starting any of this make sure u have the latest graphics and monitor drivers available.
May 27, 2008 | Acer AL2016W 20" LCD Monitor
Default monitor
Hi, if someone has upgraded your version of windows the only way to go back to a older version is installing your windows xp home edition cd, only problem with that is when you downgrade you lose everything, so you will have to make sure its all backed up. in regards to the monitor, different monitors can support different resolutions, if you cant change it up any its quite possible you got a more basic one, All the best John
Mar 09, 2007 | Dell Dimension 2400 PC Desktop
MSI NX7300LE-TD256EH GeForce  7300 LE, (256 MB) PCI Express Graphic Card Logo
151 people viewed this question
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
