Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a 18 hp briggs and stratton engine that will not start
I have a 18 hp briggs and stratton engine that cranks but has no spark. It was running fine and I shut off to talk to my neighbor and would not restart. is getting fuel and compression but no spark. model#422707-1214-01. i checked ignition switch and repaired a bad connector with new terminal with no results
  • 1 more comment
  • jesussalvado Apr 30, 2010
    Kelly Thank you for replying. The engine I have is a 1990 18 hp twin II motor not the one listed. This web site would not allow me to enter the real engine. I am sorry, The engine is a 1990 B & S and I was unable to locate any oil level switch in the engine block. If it helps it is full of engine oil. I am wondering about the coil and or module. I have checked all safety switchs and the fuse is good also. the black power wire is in good condition as well.
  • jesussalvado May 01, 2010
    Hello Kelly: I removed the cover to check coil and or module. I only found a coil with a grounding wire connected to it. the coil is grounded at the kill wire terminal even with the engine harness disconnected. I believe the problem to be the ignition coil itself. number 333. Thank you for your help. Have a Blessed day
  • jesussalvado May 04, 2010
    Hey Kelly Just wanted to let you know that the problem was a Coil or on the part listing the armature. I found that the coil was grounded and would not fire. After replacing the coil the mower had a lot more power. this was a easy fix and I thank you for just being there to help. In a shop it is always nice to have someone to ask questions of. Thank you again.
  • 3,740 Answers
A few more things to check.
1. The oil level. If the oil level is low the oil level sensor will ground the ignition.
2. Check the wiring from the seat safety switch to make sure it is connected.
3. Follow the black wires from the ignition control module to make sure none of them are chaffing and do not have a chassis ground.
If you still have problems disconnect ONE lead from the oil level sensor and see if you have spark. Most of the time these oil level sensors are the common failure.
Kelly
Posted on Apr 30, 2010
  • 2 more comments
  • Kelly
    Kelly May 01, 2010
    I think your were close on the engine number my best guess is
    Model: 422707 Type: 1516 01 Code: 91110712 This number should be on the air shroud just above one of the spark plugs. It could also be in the side of the air shroud.
    Given everything you have checked we may be dealing with something as simple as a Magnatron ignition unit failure.
    (Item 897 in the manual) Page 8.
    This is the manual I am using:
    http://www.briggsandstratton.com/maint_r...
    If memory serves me right this is an old Spirit or IC engine
    Pull the upper shroud / engine cover and unhook the wire leading to the Magnatron unit from lower in the engine. Remove the spark plugs and check for spark as you crank the engine through. If you have spark at that point there is a short somewhere in the engine wiring. If you still do not have spark then the Magnatron (Ignition module) Item 897 is bad.
    Thanks for using FixYa,
    Kelly
  • Kelly
    Kelly May 01, 2010
    I passed you some bad info... my apologies. There are 2 versions of ignition on this engine depending on manufacture date. One is electronic and the other is manual. We are talking about items 897 or 333. I hope I am not confusing you with this. What your trying to do is remove the ground / kill wire that goes to the throttle control linkage from the coil / armature / magneto to check for spark.
    I am still thinking we are dealing with a kill wire issue here as you said you turned it off and then there was "no spark." All the key does is ground the ignition coil HV transformer winding so that there is not a spark output. We are trying to locate where that ground is now... and why.
    Kelly
  • Kelly
    Kelly May 01, 2010
    Ok one more thought... if you have a multi meter... check for a bonafide ground on the black wire that goes to the ignition module. I am pretty sure is will either be a chassis ground or the actuator on the throttle control (if your mower even has it) that may have a damaged or bent tab on it. You will have to find the source of the ground to get your ignition back.
    Kelly
  • Kelly
    Kelly May 04, 2010
    I am just pleased to have been albe to have assisted you. I have been around and fixing B & Strattons since my pre-teen years. It always makes me smile to know someone learned something and fixed the problem in the process. Now it is time to catch up on that lawn that has been on hold. Take care.
    Kelly
18 HP Briggs; runs great but oil is leaking on chassis near exhaust
Posted on May 05, 2011
  • KEITH ORNDORFF Apr 05, 2015
    I have the same problem with the oil leak. Any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
Safty switch is bad ceck the brake switch on foot pedal
Posted on Nov 27, 2014
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have a 20 hp b
Posted on Oct 05, 2010
I have 18 h,p briggs and stratton very hard to crank
First check state of the battery under a load must have 12.5 or greater if battery is good check the valve setting the can cause an engine to be hard to start the valves should be approx 6mm
Jun 19, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp Briggs blowing oil into the air filter
Sounds like your valves are sticking, possibly bent w/piston damage.
Dec 14, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
23 hp engine will start great when cold, but after it run a short it will not start Brfiggs&Stratton vanguard V-Twin Vertical Ohv Engine start.
it sounds like a fuel starvation problem it is very possible theres a blocked vent in the carb. the carb will probably will need rebuilding not very difficult
Apr 09, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
9,214 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
