Question about Homelite ZR10926 16 Chain Saw
GETTING MY HOMELITE 150 STARTED.
YOUR ANSWER INDICATED YOU DIN NOT UNDERSTAND MY QUESTION. WHICH WAS. HOW DO I RESTORE THE SETTINS OF THE NEEDLE VALVES ON MY HOME;ITE 150 TO THEIR ORIONL POSATION OR AT LEAST ONE WHERE THE ENGINE WOULD IR SHOULD START, WHILE I LOOK FOR THE REAL PROBLEM? THANKS ANY WAY YOU HAVE TRIED. CAN I DOWNLOAD A BEW MANUAL? IF SO PLEASE ADVISE INSTRUCTIONS ON HOW TO DO THAT. VIC HALL
  • vic3927h May 02, 2010
    I WILL TRY ALL OF YOUR SUGGESYIONS. IT WOULD SEEM THAT ONE WILL SURLY WORJ THANKS VOC HALL
    President:
  • 2,220 Answers
Hello Vic;
Start with “L” & “H” needle valves 1.5 CCW from lightly seated, then adjust for performance as follows.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment may be indicative of a larger problem.
I searched for an OM with no good luck. Please contact them here:
Homelite.com (Contact Us)
https://register.homelite.com/contact_us/new
Ask they create an on line location where OMs can be found and down loaded please.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 30, 2010
  • 1 more comment
  • dontbother10
    dontbother10 Apr 30, 2010
    You mention your saw is in the mountains, caution please the thinner air will cause a run lean condition with the needles at a richer setting. Is there a small chainsaw shop there? Buy the attendant a cup of coffee and inquire what initial setting he/she uses. Stihls initial setting is leaner than most, add at least 14 turn CCW to what a Stihl mechanic suggests unless he specifically mentions Homelite.
  • dontbother10
    1/4 not 14 my bad,. You meant what I knew LOL. Lou
  • dontbother10
    dontbother10 May 02, 2010
    Please bear in mind if set to run at altitude it will be leaner in the valley. Do not want to see anyone toast their saw. Thanks for the the reply Vic.
    Lou
    It is richer in the mountains when set in the valley... I hate when I am wr...
  • 38 Answers
Its 1 turn out for both screws, then turn them a small amount when running to ajust for best performance
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Homelite mightylite leaf blower starts and idles but wont rev to high speed
Have you moved the needle valves? If not good. If so bad. So if you have not moved them gently turn them in counting the turns and part of turns for each valve. Jot this down. Then take out the valves one at a time and spray some carb cleaner into the needle hole. Then put each valve back in the same number of turns and try to start. If you disturbed the valves first start by seating the valves then turn out one turn.
Nov 08, 2013 | Homelite Garden
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
Homelite carb schematics
The fuel pump side goes: carb body, diaghram, gasket, cover.
The metering side ( side with the needle) goes: carb body, gasket, diaghram, cover. On the diaghram, the side with the larger disc and the holes around it and the nub in the center goes down toward the needle lever.
Any adjustment needles can be set at 1 and 1/2 turns out to start. Turn out to richen. If it falls on its face and bogs when you throttle up then its lean and needs to be richened up.
Oct 06, 2012 | Homelite Mighty Lite Blowervac
I have a Dinli 50cc runs and starts but dies when pushing throtle over half way - I have cleaned carb but did not take out needle and seat- there is gas all over carb and never use to be - does this bike...
Definitely check the needle and seat. It sounds like the fuel is rising too high. If the needle is the type with a rubber tip, it may need to be replaced because they don't stand up very well to the ethanol that is added to gasoline these days. Safe riding.
Jun 26, 2011 | kawasaki GV250 Aquila GV250 Cruiser...
What are the carberator settings for a homelite bandit sx-135 weed eater?
If it's a Zama 2-stroke carb...the reference settings for the high and low speed needle jets are... turn them all the way in till they are snug and them bring them back out about 1 1/2 turns. (one and a half ) That is a good starting point for their carbs and should get it to start so fine tuning can be done.
Jul 10, 2010 | Homelite Garden
Homelite Timberman chainsaw won't run anymore
ohhhh maybe ya burnt a hole in top of piston... are you SURE compression is OK?
Feb 13, 2010 | Garden
I have a homelite 240-hg I cant get it started i
Try some starter fluid (eather) that wil give you an indication if it's ignition or a fuel problem.
Feb 28, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite ht 17 hedge trimmer won't stay running
Homelite support page was no help.    Usually with these small engines you start the needle placment by lightly seatign the needles all the way in and then  1and 1/2 turns out.    That is enough to get the engine started, then ajusted while running almost always father in. Idel jet at idle , of course and high speed jet under load,if possible. I would start with the carb first as that is the most likely problem.
Dec 25, 2008 | Homelite 'Yard Broom' Leaf Blower
Homelite ZR10926 16 Chain Saw Logo
377 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
