Question about Motion Computing MOTION LE1600 Notebook
I have a Motion Computing LE 1600 tablet pc. The unit has been working fine until recently when I attempted to turn it on. The battery is fully charged and plugged into the adapter. When I attempt to turn the unit on there is no response. I have notice several buttons around the unit and am wondering if I disable some security setting or if there is something more serious like the power supply is dead. Thanks for any help. Hankf
3 Suggested Answers
Tualiapz
  • 80 Answers
SOURCE: Problem with extended battery
LED indicator for your laptop model
Steady Blue = Battery charged and AC adapter plugged in
Amber = Battery charging and AC adapter plugged in
Slow Amber Flash = <10% battery life
Fast amber flash = 3% remaining TPC will automatically go into hibernate
Slow flashing amber Adapter plugged in = Overheat condition
Do you have a multimeter to test the battery that you are using? check the output current of the battery.
Posted on May 29, 2009
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
Motion LE1700 Tablet PC repair
If the tablet is turning on, but not booting into your os then there is most likely a problem with the hard drive. If the computer doesn't turn on at all then the battery or charger may not work.
Apr 02, 2013 | Motion Computing LE1700 Tablet PC
I HAVE A MOTION COMPUTING LE 1700 TABLET AND THE PEN WONT WORK AFTER I FORMATTED IT. WHAT SHOULD I DO?
you need to install the Wacom driver available from their site- if it's still available- I have a copy of their drivers if it is not on motion's site.
Mar 12, 2012 | Motion Computing LE Tablets & eReaders
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
I have just got a 'new' (never used) Motion Computing LE 1600. The pen won't calibrate (way off). The USB mouse works just fine. I have tried calibrating several times. I have installed the latest...
Please check page 22 in the bellow article for how to caliberate the pen.
http://www.motioncomputing.com/resources/UserGuide_LE1600.pdf
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Oct 02, 2010 | Motion Computing MOTION LE1600 Notebook
Jul 06, 2010 | Motion Computing C5 Tablet PC
May 29, 2009 | Motion Computing MOTION LE1600 Notebook
Install new os on motion le 1600
You can use an external USB drive, either CD or DVD dependent on your OS media.
I used a Phillips drive, with external power supply, to restore to factory settings using their restore CDs. I also installed Windows Vista Ultimate from DVD, without issues :)
Mar 30, 2009 | Motion Computing M1400 CENTRINO 1.1G 512...
Computers & Internet Logo
77 people viewed this question
Top Motion Computing Computers & Internet Experts
David Payne
David Payne
Are you a Motion Computing Computer and Internet Expert? Answer questions, earn points and help others
