Question about Sharp AR-M450N Copier
Hi,\r\n Hi, My name is Wayne and I have a Sharp AR-M45on+. There is a error message that says: Code H4-00. How can I fix this problem myself? Thanks
  • clemways Apr 30, 2010
  • 4,737 Answers
The problem is related to fuser (the fuser is the black-rectangular box in the upper part of the body. You'll be able to see it when you open the left-hand side of the door). It's possible that there's overheating problem with the fuser roller. On many cases, this error displays when there's something blocking on the fuser unit.
If there's no hardware defect, you can easily fix it. Remove the fuser, check for any foreign objects like pieces of paper, thread, hair, etc.. if so clear them. Clean the unit with brush or whatever you think is good and suitable. Reinstall it. Reboot the machine and check if this helps or not.
If the problem persists, you need to reset the machine.
Let me know when you are done.
Good luck.
Thanks for using FixYa.
Posted on Aug 09, 2010
    President:
  • 1,554 Answers
The code means the fuser is not heating up. The fuser is used to melt the toner onto the paper to make the image. It applies heat and pressure to the toner once it is transferred to the paperto create a permanent image. It is what makes the paper warm when it gets out of the laser printer. The toner is composed of a hot-roll and a back-up roller. The fuser is not user serviceable and is recommended to be serviced by an authorized and qualified technician to prevent incurring further damage to the machine.
Posted on Apr 30, 2010
    Genius:
  • 1,043 Answers
That code signifies that the fuser is not heating up properly. Sometimes this error can be reset by a tech, other times the fuser has to be replaced. Unfortunately there are no service manuals on the web for your unit, so unless you have a reasonable amount of experience in repairing copy machines you'll have to contact your local Sharp tech to diagnose and resolve your issue.
Posted on Apr 29, 2010
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Sharp AR-M45ON coming up with F1-15 error code "Finisher Trouble" Can you tell me what this means and if there is an easy fix for it, please? Also, what is a finisher and where do I find it if...
Your machine is installed with finisher model is AR-FN7, it's lift up motor is working ub normally, the motor may be defective or over current to the motor or you have to change the console finisher control PWB, you can try to enter to the service mode by pressing #*c* button in the respective order then you will get another display to enter the main code then press 3, then press start, then again press 3 and start by this you can check the lift up motor working . rate this and give feed back accordingily I can give you the instruction.
May 05, 2011 | Sharp AR-M450N Copier
Code message
improper cartridge (destination error,life cycle error )
identification error
model error
type error
destination error
data abnormality
misc error
Nov 19, 2009 | Sharp AR-C260M All-In-One Printer
Sharp AR-M208N with OFH4-00 error code
Hello sir; This code require simulation to reset the procedure as follow; press "#", "interupt", "clear", "interupt", then enter 14 press start. turn power off and back on, then all set.
Sep 27, 2009 | Sharp AR-M208N Copier
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
Sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Jun 19, 2009 | Sharp AR-5320 Black and White Copier
Error Code E1-15 - can I fix this myself?
Most messages that state "call for service" are for instances where the unit is not running to prevent damage to the unit.
You should call an autherized or certified technician to work on the unit.
Apr 24, 2009 | Sharp AR-M237 Digital Copier
Error Code E 7
press"clear","interupt","0","interupt",enter14 press start.should take care your problem.
Dec 15, 2008 | Sharp AR-207 Copier
Sharp AR-M450N Copier Logo
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
