Question about Maytag M6Y12F2A Air Conditioner
AC does not cool.
The ac Does not cool and I never here the compressor start. Fan works.
  • 674 Answers
It could possibly be a bad capacitor if it has one or a bad compressor. There are some other things that would keep the compressor from running like a low pressure switch or a high pressure switch, a bad contactor that supplies power to the compressor. Usually its cheaper to buy a new window unit than replace the compressor in one if the compressor is bad. Hope this helps.
Posted on Apr 30, 2010
Testimonial: "Thanks for that. I think I will take your advice and buy a new AC"
How long for the ac fan to start working? Ive noticed that the fan does not work when i turn the ac on, can this cause my car to overheat. I check the temp and coolant liquid both seems fine.
the ac fan starts as soon as the ac is switched on
the fan is provide cooling of the condenser before the radiator to prevent high head pressures in the ac compressor
it is the fan at the front of the car mand does not affect engine temp
there is a radiator fan between the engine and the radiator that will not start until the coolant temperature reaches a set temp at which point the ECM switches that fan on
if that fan is not working when the engine is hot , check for fan, coolant temperature sensor switch , fan relay, fuses or problem ECM
Jan 13, 2016 | AC Cars & Trucks
HEIL HVAC, fan blows but no heat or AC
Your airconditioning system may be out of cooling gas, and if it has sufficient gas, the compressor might not pick when you put on the AC, and if the compressor did not pick ie start, you cant experience cooling effect, the fan will only be blowing.
Jan 18, 2013 | Cars & Trucks
Hyundai accent 2002 car high temparature during start ac
check see if cooling fan running could have faulty cooling fan relay or fuse.if cooling fan dont run when ac on car will overheat.AC COMPRESSOR PUT LOAD ON ENGINE.
Sep 06, 2012 | 2001 Hyundai Accent
Compressor and fans do not turn on until rev engine
I passed this question the first time I read it, so I will take a stab at it now.
The fans don't come on until the compressor has pumped the freon pressure up to say 150 or 200 psi. And the compressor clutch has to have voltage to engage the clutch.
I wonder if the clutch is going and needs 14 volts instead of 12 to engage ? Or the relay that powers the clutch ?
Speeding up the engine would increase voltage from the alternator.
This is assuming the serpentine belt is tight and everything else is working correctly.
I think I would swap the relay with another and put a meter on that circuit to the ac clutch to see what it takes to engage it.
Jul 24, 2012 | 1992 Buick Regal
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
Compressor keeps kicking off 1999 Buick Century AC
Your ac system is most likely low on freon, or the cooling fan is not working.
When you turn on the ac the cooling fan should stay on.
If it stays on then you are low on freon.
Nov 23, 2011 | 1999 Buick Century
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
AC not stops working when compressor starts.
how many amp service do you have in the house
May 17, 2009 | Heating & Cooling
Maytag M6Y12F2A Air Conditioner Logo
280 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
