Question about Beckett Corporation Beckett Corp 350 Gph Fountain Pump
Hello. i have a m250aul pump that had come apart. i figured out where most of the parts go except for a small ciurcular piece with two rubber seals. it looks like it is supposed to stabilize the rotor as it turns. if fiited it into the plastic piece that secures over the rotor. it works but is unstabe and thus noisy. any suggestions? thanks, bill
I am replacing the coupler on my machine due to it not agitating and noticed oil on the motor under the drum. also found a small piece of rubber that doesn't look like it came from coupler. maybe from a...
the tranny is leaking and the coupling is broke,to many over loaded loads.just a matter of time now and the machine is just gonna stop moving if the transmission oil is leaking out,just use it as long as you can or replace the tranny with the coupling,it's easy to change out the tranny,also the rubber could be from the coupling,i've seen them fall apart and rubber pieces under the motor.send the model number and i can look up the parts for you
Oct 22, 2010 | Washing Machines
How does the spring go back on the impeller?
You will need a new seal if the spring has come apart from the rubber. Almost any time you remove the impeller you should change the seal. The half of the seal that has the ceramic goes into the seal plate rubber first. The half with the spring slides on to the impeller shaft with the rubber first so the graphite faces the ceramic. Both pieces should have a small amount of teflon grease applied first to be sure they go on smooth.
Sep 22, 2010 | Pentair Pinnacle 1 1/2 - Hp In Ground Pool...
I am trying to take apart the toaster, but am having problems figuring out how to. On the bottom I removed the cord clamp and there is a black plastic piece on the bottom that appears to be a snap, however...
You need to remove the four rubber feet at the four corners, and that's where the screws are. Get a small flathead screwdriver and pry the rubber feet out of their sockets and you'll see small screws.
Jul 06, 2010 | KitchenAid KTT340 2-Slice Toaster
My crosman 1377 won't pump up. Is there a replacement part available for this problem?
The pumps seal is bad so take it apart and cut a piece of leather out to fit
Coat the leather with Vaseline and it will operate just fine for you
Jun 07, 2010 | Crosman 1377 177 Single Shot Air Pistol
Maytag epic z-ripped piece of door seal
I would say that the rubber may have gone into the system, and is probably clogging up the water outlet hose, and or the Pump. This is a bit of a "Fix' it will require the taking off of the motor and Hoses, connected to see where that bit of rubber is.http://www.letsfixit.co.uk/html/washing_machine_faq.html
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/washer/toc.htm
If you do not choose to repair this yourself, using those links above. Then please get a "Quote" for repair.
Mar 24, 2010 | Maytag EPICz 3.7 cu. ft. Washer
My Kirkland Signature Whirlpool Washer will not agitate or spin and the motor makes a load noise (like something rattling) when the tub should be moving. but it does drain water.
broken coupler. device between motor and gearcase, look under washer behind the motor for small plastic and rubber coupler. may be worn or broken. cheap part/fairly simple fix. parts house will run ou through the process or i can provide details when you are ready.
May 24, 2009 | Washing Machines
Water leaking from front door
not really due to therebeing 3 holes at the bottom of the door seal which lets water out that is stuck in the seal
Sep 12, 2007 | Miele W969 Washer
Beckett Corporation Beckett Corp  350 Gph Fountain Pump Logo
82 people viewed this question
Top Beckett Corporation Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Beckett Corporation Garden Expert? Answer questions, earn points and help others
