HomeSafe Protocol is locked with key & combination inside.
  • 1 more comment
  • lorenandgaye Apr 29, 2010
    Batteries are fine since I can see that it "beeps" when I use the numbers pad.
    Electronic numbers key pad safe is ocked with the key inside. Batteries are not the issue.
  • lorenandgaye Apr 30, 2010
    I bought this safe a year ago, and stored it in my garage, unused. Now that I want to install it, I can not open it. Not sure of the code, and the key is probably locked inside (at least, something is rattling around inside when I move the safe about). There is no serial number, and no manufacturer identification anywhere on this safe. The only identification is the name - HomeSafe Protocol on the door. Does that help?
  • 713 Answers
Please your problem is not clear enough,restate your problem in a more clearer and concise way,
Thanks
Posted on Apr 29, 2010
  • 10,515 Answers
These units have been Reported for Bad Batteries?
Check, if that could Solve the Problem.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Apr 29, 2010
    Thanks for your response!!
    Do you remember the Code Properly?
    Let me know, so that we could Proceed.
    Hope i helped you.
Is there a default combination for brinks model 5054 safe
Contact brinks they may have a master code to unlock your safe...or try a good lock smith,they may have access to the code.
Jun 11, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
RE-SETTING THE CODE
You need a key to unscrew and remove the lock cylinder on the inside of lock. Enter the old combination. Look inside the hole where the lock cylinder was and turn the metal part in there to the right. Then turn the knob or lever to clear the old combination.
Enter your new combination and turn the knob or lever to insure it works. Try it again to be sure, then replace the change plug. Always test combo with the door open.
Apr 22, 2014 | Ilco Kaba 101126d41 Lock Combination
I got the master lock speed dial combination lock but forgot my combination and it won't open. can somebody please tell me if i can reset the password?
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Aug 27, 2012 | Master Lock 5400d: Portable Select Access...
Thought I knew the 4 number combination, now locked inside. I do have the key. However, safe not opening. What is the exact procudure for combo?
Without wishing to state the obvious, I feel that I must do so. A safe is called a safe for a very good reason. If it was easy to get inside without the correct key or combination then by definition it would be unsafe.
If you have lost the combination and the key doesn't work then you can either try every combination until you get lucky or you must consider calling out a locksmith who will usually open the safe destructively (often by drilling out the lock) or even by using an angle grinder on the hinges.
Sep 17, 2010 | Office Equipment & Supplies
Master Lock 5400D Key Storage Combination Lock box i reset it combination a couple of days ago and it worked fine until today. Now it won't open with the new combination. How can I get in to it without...
Two solutions: (if the box is closed and it is attached to something)
Jun 25, 2010 | Master Lock 5400d: Portable Select Access...
My safe is lock with book inside
i guess you need the combination
Sep 09, 2009 | Dishwashers
Same problem - I have the key but no combination.
You can contact Honeywell, they are providing support for Binks safes. Their number is 1-800-223-8566
Aug 11, 2009 | Sentry Fire-Safe Media File - SEN6720
OSD Lock Problem
I have a hanns g 22" widepanel , I had the same problem with lockout. I had my monitor disc and looked on it, or in a manual if you still have it. Here is the combination I had to press and it worked. I pressed the arrow buttons and the menu button all together a few times and it unlocked. Try that!
Function Key Lock:
Press the <「Volume -」, >「Volume +」and the 「Menu」buttons simultaneously to
enable the Function Key Lock. When the Function Key Lock is enabled, only the Power
button is active. Press the <「Volume -」, >「Volume +」and the 「Menu」buttons
simultaneously again to unlock the function keys.
Aug 03, 2008 | Hannspree HW191D LCD Monitor
k24674
