Question about Sony KP-61HS10 61" Rear Projection Television
Blurry screen KP61hs10
Having a simlar problem with mine. Picture is blurry at all times. Tried to flash-focus it to no avail.. Seems a little clearer on right side of screen, but not much. Some of the brighter white text has a faint reddish hue outline. Any ideas on this?? Should I try the grid thing in the Service mode? (not too familiar with those settings)
Thanks in advance
  • 3 more comments
  • Dave MacPhee
    Dave MacPhee Mar 25, 2008
    Thanks for the reply. Went into the convergence settings and took a look there. I can move all the colours (although there is a white grid that is fixed and cannot be changed). Everything seems to be lined up pretty good. The red was a little off, but when adjusted, didn't seem to make that much of a difference. Perhaps there is something else that can be done?
  • Dave MacPhee
    As an additional note, don't know if it means anything. But when I was in the convergence settings, the crosshair (litte square box I could move around the grid) was nice and crisp when it was green, but when I changed it to red or blue, it became rather blurry.
  • Shark42 Mar 28, 2008
    Just in the last few months I have been having the same type of problem. However, on my set the red led starts flashing about 5 times every few seconds and if the picture is bright then it will clip off and then come back on. This will continue as long as the picture is bright. I have reduced the brightness just so it will stop, but this does not work all the time. There also seams to be a problem with the color as there is a red tent to the picture and it is not as sharp as it used to be. Any suggestions would be great.
  • Dave MacPhee
    Dave MacPhee Mar 28, 2008
    Thanks Troylove11 for your reply and continued support in this matter.
    Well, I finally caved in and called a service tech. Right from the get-go he said it was the picture tube, but opened it up to take a look.. Upon inspection, when looking directly into the Red tube, the picture was way out of focus (I saw it for myself, not very good), again, he said the tube has gone and I need to replace it.. A $500 venture.. A little steep for me. After humming and hawing, he did some manual adjustments on the convergence settings, and wow, picture was clear again.. He said it is kind of a bypass procedure, and may not last very long..
    After a while, the tv will turn a purple colour, and then back to normal. I am worried this fix may not last long..
    Any input on solutions??
  • Dave MacPhee
    Dave MacPhee Mar 29, 2008
    On an additional note, I'm going to give you a fixya rating, because you did specify check convergence settings, and crt solving. and because I appreciate your input..
    Also, any additional input and/or solutions would be great..
    Thanks
    Genius:
  • 1,153 Answers
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Posted on Mar 25, 2008
  • Lashawn Robinson Mar 25, 2008
    Well one way I repair sets like this is to open back of tv and put something over the CRT's. And do 1 colour at a time. Like for the blue, cover the red and green with something so you can see only a blue and then if blue is blurry there is a blue focus adjustment you can turn, it's above or below the blue screen control. Try not to change the screen control, it would interfere with your color settings. IF you cant stop it for being blurry then the CRT coolant fluid needs changing for those colors or all at one time.
6ya staff
SOURCE:
Blurry screen
Well, this could be an issue with how you are focusing the camera or what your exposure settings are too high. Try looking up a tutorial on how to frame a shot and set up your camera.
Hope this helps.
Nov 18, 2013 | Sony Video Cameras
Image is not clear when taken - picture is fuzzy
what camera model are you using? Is it possible that the auto focus is turned to manual?
Jan 26, 2018 | Nikon Coolpix S-series
Blurry Picture
I know these models came out around 2001, and I'm afraid that the problem sounds like it is related to the bulb going bad.
This article outlines how many TVs from around the turn of the century have had similar problems to yours.
I know bulb replacement is an option. You may want to call around to TV repair shops and see what your options are. In the end, though, it may be time to start saving up for a new TV.
Jan 31, 2010 | Hitachi 43UWX10B 43" Rear Projection...
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
I just installed Logitech 9000 web cam and the video is blurry
The black face plate. Turn to the left and the right untill the picture become clearer. You will need to manually focus the cam
Feb 05, 2009 | Logitech Webcam
The picture seems to be blurry or out of focus
thats how mine is. I don`t know who to ask how to fix it.
Jan 26, 2009 | Hitachi 50UX58K 50" Rear Projection...
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
Blurry picture
Did you accidentally turn on SVM? Make sure it's off. And make sure you haven't switched to a different picture mode by mistake.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
260 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
