Question about Stanley Pneu Roof Stapler
Won't shoot nails
Hitachi round head nailer. it just makes an ipression in the wood. does not shoot the nail. can't see anything stuck. now what?
  • 4,234 Answers
Usually this is because the "loader" is not moving the staples into the correct position. Make sure that the staples are loading correctly and that they move on the rail smoothly. Also, the spring should be pushing the staples toward the plunger. If the spring can not move freely, this will occur as well. Without seeing the actual gun, I cannot say for sure where the problem is, but the above are the first areas to look.
Dan
Posted on May 10, 2010
Two nails jammed in the hitachi NR83A how do I get them out
The only way that I have been able to remove really stuck driver is to remove the head and cylinder so that you can place the body of the gun against piece of wood (this will prevent the head from cracking) with nose of gun pointing up. Then Use a broken driver blade ground narrower to allow for stuck nail to pass and strike with large brass hammer.
Mar 07, 2013 | Tools & Hardware - Others
Hitachi roofing nailer shoots every other nail & doesn't sink the nails it shoots
i think you have two different problems , replace the feeder spring, and replace the oring on the driver piston. also make sure that the coil of nails is perfectly round if they are dropped or squeezed tool will not work right
Sep 11, 2012 | Hitachi NV45AB2S Coil Roofing Nailer
I inherited a Bostitch N805B uses 28 degree .113 and came with clipped head nails. Will it shoot full round head nails?
I could only find a Bostitch N80SB full round head nailer in their lineup so I hope that's what you have. No it will not fire full round had nails because they are stacked at a lower angle to accomidate for the full head and material used to hold the strips together. Senco does make a full round head nail that fits their clipped head nailers but it does not list the Bostitch nailers as one they will fit into so I don't know if they will work in your gun. The Senco part number for their three inch, full round head nails for clipped head guns is K527APBK.
Jan 31, 2012 | Tools & Hardware - Others
Hitachi nr83aa shoots out nail and it bends last inch of nail over
One problem may be your air pressure at the gun. It should be between 90 and 100 psi to fully drive the nail fast enough to prevent nails being left high in the work or bent over. Bent nails can also happen if you are driving nails into very hardwood or hit a knot in softer woods but not usually with framing nailers. Another thing to look for is a rounded off driver that is slipping off the head of the nail before it is fully driven into the work. The tip of the driver should be round (some have a crescent moon shape) but square to the sides. If you need a new driver the part number is 878-630, shop the web for one of these, they run beteween $80 and $100 plus shipping.
Jan 02, 2012 | Air Tools & Compressors
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Round head framing nailer. shoots 2nails
Check to make sure the striker bar is not marred or bent. This can cause two nails to be driven at once.
Make sure you have the right kind strip nails.
Some brands (Cheaper bundles) tend to do this alot!
Hope this helps!
May 26, 2010 | Dewalt D51850 20° Full Round Head Framing...
Hitachi NR83A2 nailer pushes next nail down
Are you using full round head nails?
The hissing indicates your O-rings are worn out and need to be replaced. This is not covered by warrenty and is common for all nail guns. Lots of kits are available on Ebay or your local Hitachi service center should stock them.
Hope this helps,
Cheers
Jan 22, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Can I use paslode roundrive nails in a Hitachi NR90GC Gas Nailer
Yes, BUT the paslode Round drive nails and known to cause driver jamms due to the excessive paper used in the spacing of the nails.
Oct 27, 2009 | Hitachi Tools & Hardware - Others
Nails ride over each other and don't shoot straight
Check and make sure your using the right nails. Are they held together with plastic? This should be a 21* full round head nail with plastic collation
Mar 10, 2009 | Hitachi NR83A2S Framing Nailer, Full Head,...
Won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Sep 24, 2008 | Hitachi NR83AA3 3 1/4" Clipped Head...
Stanley Pneu Roof Stapler Logo
79 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
JOHN LAPIER
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
