Question about Sylvania LC320SS8 32 in. LCD Television
Blown fuse don't know how to find shorted out component
  • 975 Answers
Open the unit and look for a small round glass tube with a very thin wire inside , check if wire is open .hope this helps
Posted on Apr 26, 2008
Show how to replace power outlet fuse for 2006 Toyota Camry
Interior Fuse Box Location 2002 2006 Toyota Camry 2006 Toyota Camry LE 2...
The video above shows how to replace blown fuses in the interior fuse box of your 2006 Toyota Camry in addition to the fuse panel diagram location. Electrical components such as your map light, radio, heated seats, high beams, power windows all have fuses and if they suddenly stop working, chances are you have a fuse that has blown out. If your Camry is experiencing electrical problems, you should always check the fuses first, because they are relatively easy to check and cheap to change. Some Toyotas have multiple interior fuse boxes including in the trunk - the video above will show you where the interior fuse box of your 2006 Camry is located. If your Camry has many options like a sunroof, navigation, heated seats, etc, the more fuses it has. Some components may have multiple fuses, so make sure you check all of the fuses that are linked to the component in question.
If you need to replace a blown fuse in your Camry, make sure you replace it with one that has the same amperage as the blown fuse. If checking and replacing the fuse for the component in question doesn't work, we recommend seeking assistance from a trusted professional mechanic. They should be able to figure out if the component needs to be replaced or if there is a short or some other problem with your Camry.
Good Luck
Feb 22, 2015 | 2006 Toyota Camry
How to find short circuit
Different circuits needs different ways. You can start by checking which fuse gets blown when replaced and check what circuit that fuse supplies it's power to. That will narrow down your search to within that circuit. Next remove all components that are connected to the circuit. Replace fuse again. If it still blows, that means that the supply lines is shorted to ground. REMEMBER. Fuses gets blown when its supply line is shorted to ground. If fuse does not blow, connect each component one at a time. The component that blows the fuse once connected is the one that is short circuited.
Jul 20, 2014 | 2003 Dodge Durango
SAMSUNG SP-50L7HX DEAD FUSE BLOWN BLACK OBVIOUS SHORT CIRCUIT ANYONE KNOW ANYTHING IF BOARD REPAIRABLE O
Try shopjimmy.com who carries almost all the Samsung boards--if fuse right where power cord does come in trouble is right there.
Aug 30, 2012 | Samsung Televison & Video
Power failure
if their is no power indicator at all that was mean the power supply failure. look for blown fuse, if the fuse is blown with darkened color you need to check first other component that get shorted pin before you replaced the fuse like zener diode and fet transistor. if you don't have an idea on how it will be trouble shot just send it to the service center near you.
Aug 03, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
My dvd wont turn on
is there any power indicator? if none,look for the power supply board replaced blown fuse. if the fuse is blown with darkened color that was mean their is a shorted component parts in the PSU or in the main board.usually rectifier diode and regulator ic.hope this can help just let me know if you need further solution.
Jun 25, 2012 | Televison & Video
I have an LG 42PX3RVA. The screen went blank, but there is sound. I don't know it there was a "pop", because I was not at home when it happened. I have disconnected the power and checked all...
Test the fuses using a fuse tester, if you don't have one then use a flashlight and some wires,
connect the light in series with the fuse and the batteryfor the light if it turns on the fuse is good if not then it is blown and should be replaced.
Jun 29, 2011 | Televison & Video
My 1990 acura gs fuse always blown up i replace new fuse wen i turn on the back light my fuse blown again
Fuses only blow or fail for 2 reasons
A high current load or a short
Replacing a fuse ,won't fix a thing,
as you found out
You should only have a fuse failure
every 6 or 8 years on any vehicle
If you get a wiring diagram or know
what doesn't work, you should be able
to find the failed component
Sounds like a short, in an old wiring
harness socket.
Feb 11, 2011 | Acura Integra Cars & Trucks
I pulled a shorted fuse that was causeing some clicking. the clicking stopped and the car wont start. the fuse went to the lower beams it said in the manual. not sure why the car wont start.
do you mean a fuse that is blown? pulling out a blown or shorted fuse wont cause any changes, since the circuit it feeds will be isolated anyway. It sounds like you may have pulled out a good fuse that powers some essential components. will the car start when the fuse is put back in?
If the clicking you hear is due to a faulty electrical component, then try to identify which component the noise is coming from by listening to wear the clicking comes froms. Pulling out the fuse to that component will only cut the power to it, it wont provide a fix.
Nov 09, 2009 | 2005 Ford Escape
DVD Player
The blown fuse is caused my an overload in the circuit. It can be caused by a faulty component or just some short circuit..Yes, if the fuse has blown off, there is a "chance" that componets inside may be faulty which caused the overload in the first place.
Mar 03, 2008 | Philips HTS3500S System
Sylvania LC320SS8 32 in. LCD Television Logo
75 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
