Question about LG 37LC2D Television
LG 37LC2D HDMI no signal (picture or sound) + crackling on audio
HDMI input worked for months but now shows "no signal" giving no picture or sound via HDMI input. Tried new cable and with SKY+HD box and HDMI laptop as the signal source but symptoms the same. Now watching SKY+ on AV3 input but this has crackling on audio since the HDMI fault, sometimes very loud crackling and also even crackles when volume on 0 or muted!
Hope someone can give some pointers before i take the back off..
Thanks
Ian
  • 1 more comment
  • Ping192 Apr 29, 2010
    also tried factory reset and when scanning for channels on its re-boot it only finds the Analogue TV channels then stops at 50% not finding any DTV channels at all.. have to downpower to exit as it seems to lock up. Also locks up if manually trying to enter the menu item "station/auto program" goes to blank screen after a few seconds - cycle power to recover.
  • Ping192 Jan 17, 2011
    I have since fiixed all my problems above - check (and replace) all the electrolytic caps on the power supply board (use high temperature ones for long life) - a few of these were dried out and low in value - now perfect sound and picture again! HDMI, DTV and sound crackles all caused by these faulty PSU caps.
    hope this helps others
    Ian
  • Ping192 Apr 07, 2011
    i replaced them all on the psu board as half of them had dried out.. i like my repairs to be solid! Could just swop the low reading ones tho as some are more prone than others (near heatsink or high ripple current useage) RS and Farnell have suitable replacements, but as long as they fit size-wise (some would be too big physically) and volt/uF the same or a bit more they will be ok. hope you have sucess.. this has got to be a common fault im sure..
I have the same problem. i think they just get old, i solved the audio problem by taking the cove off the back and disconnecting the speakers, i now just use PC speakers, works grand. i haven't solved the HDMI problem yet..
Posted on Jan 17, 2011
  • 3 more comments
    Fixed my set now :) replaced power supply electrolytics (see above)
  • MrShameless Mar 08, 2011
    thanks PING, ill have a look at mine. great help :)
    oh, where did you get all the right electrolytic s? :0)
  • stt9 Apr 07, 2011
    hi - i have the same problem, i checked a few of the caps and got no reading so replaced, but did you replace all of yours?
    i replaced almost all of them.. half were very low in value. RS/Farnell do suitable hi-temperature replacements. Check physical size as some may be too big to fit space and can obv. use higher voltage types if needed for availibility.. for what it costs when u DIY this is a solid cheap repair.
    good luck fixin ur LG! :)
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
LG 60pk950 - HDMI inputs 'No Signal'
Try manipulating the TV mode selection to HDMI 1, 2, 3 or 4, whichever the number of HDMI ports are available.
Nov 02, 2015 | LG 60PK950 High Definition Plasma TV
Our LG television seems to not be processing signal properly, the picture and sound is very slow and sounds distorted. When connected the playstation comes up with no signal. What could be wrong?
a few issues , you need to use the appropriate cables, for example , play station needs an HDMI only ,make sure whatever input the hdmi is in , , thats the input you use fot the play station .
it sounds like your using multiple wiring , im guessing because of the lack of info giving on your help request ,. make sure your using digital cabling for each device your hooking up. also , are you using a sound system , a tuner .... you should be using an HDMI or 2nd a component cable , those are the 2 best , all others are going to cause audio issues. give me more info and ill be able to tell you exactly how to fix your problem. good luck ..
The Cable GUY .....
Mar 11, 2015 | LG Televison & Video
Lg 42lt75 used to work with a bp630 blue ray player but now shows "No Signal".
have you tried connecting ur laptop via hdmi to tv? if it works you should probably check tv settings for hdmi, if not then it is possible that the hdmi controller from tv to have some problems, i had a similar problem with a philips tv and took it to service ending up in a total replacement of motherboard and led display
Mar 09, 2014 | Televison & Video
My LG model # 37LC2D won't turn on. The green power light will blink on standby then stay green. The screen will be black. Occasionally the picture will work fine and other times it is either black or...
Hello there,
I believe the Audio/Video Inputs/Outputs could be going out .
If you are using the HDMI try the Component cables and connections or AV cables with the S-video
if you swap the cables around and the problem is still there let me know and we try a few more steps thank you and don't forget to Rate
Jan 26, 2011 | LG 37LC2D Television
(Pioneer PDP-4340HD Plasma with PDP-R04U Receiver) My HDMI input works, however having a computer or Xbox connected via HDMI I do not have the optical output signal thus I can not hear audio through my...
I don't have a direct solution but I am having the same problem when connecting (1) my Apple TV (2) my Blu-Ray player, etc. via HDMI. I also have a digital camera that puts out HDMI, and when I hook it up, I get the same story -- video only, no sound through the optical digital output of the TV receiver.
I am guessing that the HDMI inputs were an afterthought on this model, especially since the printed manual doesn't even show or mention the HDMI inputs at all! So my guess is that the TV's receiver does not convert the sound from the HDMI to the optical digital output. It does, however, send the amplified HDMI sound to the stereo speaker outputs on the monitor. It appears that only the digital tuner's 5.1 sound comes out on the optical digital output.
This is what I have observed, for what it's worth.
Nov 04, 2010 | Televison & Video
I want to setup my logitech x540 surround sound through my tv (which is LG 37LC2D the jacks at the back are Inputs: AV In 1 RF In Y AV In 1 S-Video In 1 Scart Jacks 3 Component in Audio 1 Digital Audio...
Based on your query "...which jack...put the green cable ...", I would suggest that you replace that green cable with a 3.5mm Stereo Phone Male to Twin RCA Male as shown below.
19ba6b8.jpg. The stereo phone would match the green INput ((Front) of the Logitech X-540 while the twin RCA (white & red) would match the RCA AUDIO OUTput of the LG 37LC2D.
Of course hooking it up this way would not fully utilize the 5.1 features of the X-540 (Rear and Sub/Center) but the TV sound will come out of the front speakers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 09, 2008 | Televison & Video
Televison & Video Logo
2,250 people viewed this question
Computer Repairing
Computer Repairing
