Question about LG LDF6810 Built-in Dishwasher
Dishes stay wet after going thru dry cycle. Can
Dishes stay wet after going thru dry cycle. Can you tell me if there's something I can do to fix that. Dishwasher model ldf6810st/01
  • 901 Answers
Check hot air. Refer service center
Posted on Apr 30, 2010
  • DBBs Sep 11, 2011
    fill with jet dry or like as unit does not really go thru dry cycle when that tank is M/T. I have one of these and they **** big time
When i turn on the dishwasher and cycle has run and its finised . the dishes come out cold and wet
sounds if the drying cycle isn't working , most washers use a small blower fan to move air thru chamber 2 dry dishes , these little fans do rust up over time and need replaced sometimes , id say finding fan and cking it for rust and freedom of movement is a first step in this , most times there inside door of machine
Dec 21, 2016 | Dishwashers
Dishwasher washes dishes but does not dry even though that display shows dry icon
First ,Check for a water puddle on the bottom of the dishwasher .If you have water there, you more than likely have a plugged drain or drain hose, or bad drain pump (less likely) If no water is there see if the dishes are hot after a cycle. If they are not you could have a bad heater (that circular thing on the bottom of the dishwasher) other problems could be the timer or computer Depending on the model brand and age of the dishwasher .One last thing there is a vent to let moisture escape that could be bad but then you would have hot wet dishes
Aug 07, 2014 | Blomberg Dishwashers
Dishes still wet upon end of cycle
Check if the heater is working. This can be done by checking if the dishwasher has steam and dishes are warm when cycle is complete. Also check if the Rinse aid has not finished. Make sure the Rinse aid dosage is not at too low.
Jul 31, 2014 | Electrolux Dishwashers
Have bosch she45 that stays wet inside after cycle completes. some of the dishes are wet also, how do I stop this
First of all, Bosch is my Favorite! Secondly, maybe your heated dry button is not on. Are you keeping the door closed until the dishes have had a chance to completely dry? This unit has a system that drys with the walls of the d/w as long as the door remains closed. I hope this helps you. :>)!
Aug 14, 2009 | Dishwashers
When the wash cycle is done, the dishes are wet
It seems that the newer dishwashers are worse at drying dishes than their tupperware melting predecessors were. They have all been tuned down, and do dry less. The only thing that you can do is to set your machine for the hottest wash, power dry and use a rinse agent that provides a sheeting action. Some folks use white vinegar as a supplement to their rinse aid, which has the added bonus of killing mold. Water also stays attached if the water has laid down minerals as noted by cloudy glassware. If this is the case, a dishwasher filter (dishwasherfilter.com, $70) might help. We try to wash hot, with a power dry and use a rinse aid/vinegar. Then, when the cycle is complete, but the dishes are still hot, we open the dishwasher, and "jiggle" the racks to get the excess water off of the glasses, and leave the dishwasher open about 2" at the top, so the dishes will continue to air dry. This has been an effective method for us.
Best regards, --W/D--
Aug 03, 2009 | Siemens Dishwashers
The dishes don't get dry enough
I was able to fix this by using rinse during the cycle.
Nov 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes are ALWAYS WET!!!
If the dishes are made of plastic they will be wet , they don't retain heat when in the drying cycle!
Aug 10, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Wet dishes
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
LG LDF6810 Built-in Dishwasher Logo
712 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
