Question about Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack
How to get the back off to renew batteries I need to put new batteries in the units and am unable to open the back to get the old batteries out
    President:
  • 2,761 Answers
Press and slide the battery compartment door to remove it.
Need the operating instructions for your radios? You can download/print it here:
http://www.uniden.com/pdf/GMR325-2om.pdf
Bill B
Posted on May 03, 2010
How to open it to replace battery?
U need special miniature screw driver set to do the deed. The screws are located under the stickon tag that runs for the entire length of the unit on the bottom. (For Garmin GPS)
When you go to open the unit do so very slowly because on one side of the unit there is a ribbon connecting the front to the back of unit and if you open the wrong way you will break it. Carefully remove old battery, replace, and put back together.
Oct 08, 2015 | GPS
Our Kreisler air conditioner is rarely used, is 7 years old and will not switch on. The batteries have been renewed on the remote. Could it be the sensor in the unit? Do I need a service man?
The first thing I would suggest it to verify that power is provided to the unit. You should get a display on the face of the indoor unit if there is power. If there is power, try turning the outdoor unit off for a few seconds and back on to reset the controller. If your unit is like I think it is, the indoor unit receives its power and control signal from the outdoor unit, then the remote utilizes a rf signal to control the system. Also try new batteries in YOUR remote.
Jan 04, 2015 | Heating & Cooling
The new battery (less than a year old) drained and won't re-charge after I jump and run the engine for 30 minutes. Is this a sign that my alternator needs to be replaced?
yes most definatly ,start engine and take the neg battery terminal off and if engine stops then renew the alternator with a bosch replacement factory reconditioned exchange unit so you know its right
Jan 29, 2011 | 1985 Ford F 250
I've had this shaver since new and now it seems to need frequent charging. Could the battery need renewing or is this possible?
Thisis the classic symptom of a worn out battery. You will find a replacement battery for model 6853XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To replace, start by removing the two scres on the back cover. Remove the back to access battery compartment. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Jan 19, 2011 | Norelco ReflexPlus 6853 XL Electric Shaver
I had a problem telling me to open tray because it was unable to read disc and the drive was making grinding noises so i ordered a newcd drive for i and installed it and now it is reading games as dvds so...
I hope you kept or old drive because here's what you needed to do. First I hope your replacement drive was the same model and firmware versions as your original. This is necessary because Microsoft put a failsafe key to prevent modifications. This information can be found on top of your old drive.
After you get both drives together it's a simple fix. You need to open your old drive and take out the board. You will have to then do the same to the new drive. Next, swap the boards and put them back together. Then just put the new drive (with the old board) in your Xbox and viola! it's fixed!
The reason this works:
Your old drive's hardware was malfunctioning so that's all that needed to be replaced. So you keep the board since that has the key that you need.
For a visual explanation of this: visit http://www.youtube.com/watch?v=T_xSsNmjqKI
Jan 26, 2010 | Microsoft Xbox 360 Console
New battery for technosonic portable dvd player DVP 2111
unplug 1st ! Open the unit.. look inside see if there is a nickel size battery in a clip on the ckt board. if you can, remove it and take the battery to radio shack to match it to a new one. put it back the same way you took the old one out. If you unit has a soldered in battery you will have to take the unit (if you can't solder) to a electronics repair shop. they should be able to fix you up for maybe $39 or so plus the cost of the battery.
Nov 14, 2009 | Philips DVP5140 DVD Player
Replace battery 2003 CTS
You will be fine replacing the batt. The only code that you will need is for the radio if it is stock. You do not need to worry about the computer it will be fine. You can get the code here at this site though.
http://www.radio-code.com/index.htm
Good Luck
Please Rate
Dec 19, 2008 | 2003 Cadillac CTS
When power goes out, it turns off.
Yes, that could be the case. Eventually, a battery will be unable to recharge and would need to be replaced.
You could get a new battery from a local battery specialty store like Batteries Plus or Interstate Battery, or online at www.replacementupsbattery.com. A new battery would be about $30. If you took your old battery there, they could recycle your old one, as well as match it up with the correct one you would need (BP7-12 battery).
We have a 3 year warranty on all our battery back up units. If you have any questions, you could contact us here at CyberPower Systems Technical Support at 877-297-6937, M-F 8-5 Central, or email us at tech@cyberpowersystems.com.
Sep 14, 2008 | CyberPower Office Power 585AVR...
Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Logo
347 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
