Question about Sylvania LC320SS8 32 in. LCD Television
Sylvania lcd color tv
When I plug the tv the fuse blows.
I have replaced this fuse with the same type slow burn fuse and It blows as soon as I plug it into the wall
I blew the fuse (125v 4A) so I replaced it and it blew again. I tried a different outlet to make sure it wasn't the plug strip and it blew again. Anyone have the same problem or know how to narrow down what component is shorted out?
  • 2 more comments
  • Anonymous Apr 06, 2008
    Watching tv and lost all picture and sound. Found the fuse to be blown. Replaced fuse and plugged back in. 2nd fuse blew instantly. Bought a surge protector and replaced the fuse again. Again it immediately blew upon plugging in. Tv shop wants $100. just to open the back. Any thoughts?
  • jennypooh Apr 20, 2008
    my tv will not say on as soon as i turn the tv on it turns off with sound or color
  • curtislow28 Oct 22, 2008
    turned tv on and it immediatly turned off. no power. how can i replace this fuse others are talking about?
  • securegirl25 Apr 29, 2009
    +I have the same problem,replaced the fuse and it blew out every time,tried three fuses...
  • 16 Answers
If you have replaced the fuse already then you know how to open the back of the set . The problem is more than likely one of the diodes in the rectifer circuit . They will be the four large black components The bad one will have to be desoldered and a new one soldered in its place . It will take a small amount of technicial ability but can be done easily at home.
Posted on Oct 25, 2008
  • 124 Answers
I would definitely check your home wiring. An AC Electrical Wire Tester runs about $5.00. You just plug it in and three lights will light or not light depending on your wiring.
Posted on Apr 10, 2008
SOURCE:
Microwave keeps blowing fuse as soon as plug into wall receptacle.
Just to clarify: With the door closed, the fuse will blow as soon as you plug the unit in? Have you checked all three microswitches? One acts as a crowbar.
Dec 27, 2017 | Microwave Ovens
Why wont my tv come on after I unplugged it from the wall while it was on.
hi yes this is possible, there's a glass type inside the tv, but beware if you replace the fuse and it blows again there's a dead short, thanks
shaun
Feb 13, 2017 | Panasonic Televison & Video
Samsung fp-t5084 fuse fix is the replacement fuse slow burn or fast burn?
I'm certain it uses a T12amp slow blow type. I have the exact same model, you can replace the fuse. The TV will for a while, but that fuse will blow again. You will need to replace the power supply board for a more permanent fix.
Dec 21, 2012 | Samsung FPT5084 50 in. Plasma HDTV
Power board fuse blowing
Remove the power board from the TV and look at the other side of the board. You should find the burn-out and then trace the printed board for a short.
Nov 28, 2017 | Olevia LT23HVX 23 in. LCD Television
Flat panel tv blows fuses
next to the fuse that blows is 4 large black diodes2.gif.one of those is common to short out. the bad one would give you areading of zero ohms when checked with a meter. or just replace all 4.most likely its location D603. hope this helps
Nov 10, 2008 | Sylvania 6626LCT 26 in. LCD Television
Blows fuses repeatedly on IWT3206 model
when electrical storm was going on the t.v. was on ? if it is was then return electrical / heavy lightning it may burn the parts.shorting through your mains and anteena conections, please clarify
Jun 24, 2008 | Televison & Video
try a diffenrt outlet if it still bunrs of a different fuse! could be the fuse not big enough for the different appliance on the circuit !
i would suggest take it to a tech it could be a problem in the tv that could cost only a few $ to fix !!!!
against trying to much to plug it in and out you could burn transistors or other expensive part of the tv!
Jan 14, 2008 | Sylvania 6632LG 32 in. LCD HDTV
Follow up on "no power to my tv"
3d picture ...sounds like to me a convergence amp issue...what type of tv is this?
Dec 01, 2007 | Televison & Video
Fuse
If the fuse blew again then there is more than likely a problem with one or more of the boards components. First start by unscrewing the power supply and looking on the underside, you may see some burn marks. If you do then it is likely that the component above the burn marks has blown and needs to be replaced. If you do not see any burn marks then the best place to start is with the diodes on the board. If its still not working, e.g. the fuse blew again then it may be that the problem lies elsewhere on the power supply... Good luck.
Dec 06, 2005 | RCA RS2020 CD Shelf System
Sylvania LC320SS8 32 in. LCD Television Logo
479 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
