Question about Car Audio & Video
Locked out of pug 306 1998 clarion radio. When
Locked out of pug 306 1998 clarion radio. When power is on I only get four short lines on the LCD. Only got the car 3 weeks ago and it has done this since day one.
  • crag38 Apr 30, 2010
    cant inpute any numbers into the sterio. All there is are 4 short line dashes. If I could input a code would the sterio say CODE on the LCD or do I have to hold another button to activate this?
  • Car Audio & ... Master
  • 4,932 Answers
It requires a code to be entered
Posted on Apr 30, 2010
Testimonial: "very speedy response. Thankyou"
  • xxxxxx xxx Apr 30, 2010
    It may be because someone has entered several wrong codes in the past.
    If you have a BND button, then press that briefly to see if the display resets.
    If not , then try leaving the radio SWITCHED ON ...UNDISTURBED to see if it resets.
    The Code Entry Instructions will depend on the exact model of radio so it will be one of the ones on this list ( The most common is the PU-2294)
    http://www.radio-code.co.uk/post_in_radi...
No sound on radio or CD,speakers working nice but dont make any sound
Possible damage to radio output ic if no audio. Output failure is usually due to shorted speaker lines either together or to ground. You can check your speaker lines at head unit and they should have approx 6v dc on +&- lines each channel. If this is not present then most likely is
output failure, if ok then is internal fault possibly with vol control ic or
power supply.
Mar 16, 2014 | Clarion Car Audio & Video
Hi i just bought a pug 106 with no stereo,i bought one from a breakers but need a code it is a Clarion PU2294a serial no CL0401Z0518204, i,ve tried 3 different codes to no avail, cheers
The only Clarion code available for free from anywhere on the Internet is if yourradio also has a BARCODE SERIAL NUMBERbeginning with C 7000000 + + ++ on a label somewhere on the metalcasing. If not then it will only be available from your Main Dealer or a Decoding Service oryour local Car Radio / Audio Store who will connect a laptop to read/recode thememory chip (EEPROM) inside your radio
Apr 19, 2011 | Car Audio & Video
I need a radio code for a pug 106 serial no CL0401Z0495037 model pu 2294a thanks
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
Sep 09, 2009 | Car Audio & Video
Clarion 3475 speakers wired, player wont turn on
The RED from the clarion wire must be hooked up to a switched power source ... that was wired to your old radio, then press the reset switch, and it should then turn on.
May 05, 2009 | Clarion DRB2475
1993 SAAB CSE LOCKED STEREO
If this stereo is a clarion and original equipment and uses a a four digit code. First thing you do is with the power on to the radio, push and hold the band button for a few seconds until you see the word "code" on the radio display. Input the code and radio should work. If that doesn't work, then if you have tried to input a wrong code several times then radio will lock out. So what you need to do is
the radio has to be on for one hour uninterrupted, then you can do the band button procedure , code input again and hopefully the radio goes on. Hopefully this helps. Please advise results
Feb 21, 2009 | 1993 Saab 9000 Hatchback
CHANGED BATTERY IN 93 SAAB 900 NOW MY RADIO WON'T WORK
Someone put the wrong security code in the radio. Hold the DNR button down and the code will clear. Be sure you have the correct code to enter after clearing the current one.
Jan 24, 2009 | Clarion ABD340MP AM/FM CD/MP3/cassette...
Car Audio & Video Logo
150 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
