Question about Dryers
Have zanussi condenser dryer tc481w. smell of burning,
Have zanussi condenser dryer. smell of burning, found that belt just frayed ready to snap, main cyliner od dryer not turning but motor poering smaller wheel. but when i opened dryer i found a small white spool snapped in two, it like a mini ogre. any idea's what this off. and is dryer fecked as main drum not turning as belt is stil intact
  • 236 Answers
SOURCE: Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Posted on Feb 16, 2008
  • 1462 Answers
SOURCE: Old DANBY elec dryer DCD411 - drum belt snapped
most belts have the length written on or take belt to a good general spares stockist and see if it can ve matched
Posted on Aug 31, 2008
ned_san_jose
  • 234 Answers
SOURCE: Dryer smells like something is burning. Heard a
The burning smell usually comes from an overheating motor. Onces it heats to a certain point, it will trip the thermal switch on the motor. Motor should be getting around 11 amps. Best of luck :)
Posted on Sep 15, 2009
SOURCE: how to fit the drum belt on zanussi tc481w
you have to release the back and in some models you need to separate the switches at fron from panel
abyway the belt is very easy to change in the hotpoint as it just slips out
when replacing it make dure is back at right position otherwise will not turn properly
I do not do this any longer as lenghty and not more economical task
Posted on Sep 27, 2009
  • 389 Answers
SOURCE: zanussi tumble dryer tds 280w front gasket snapped
it is the drum gasket that goes round the inner drum that forms a seal and acts as a buffer for the drum to ride on if not replaiced the dryer will get noisy and wear the drum out they are stuck on with a glue
Posted on Nov 06, 2011
How to replace belt on zanussi tc 481w
When the belt is installed, the idler with properly tension the belt.
May 08, 2012 | Zanussi Dryers
Zanussi 7102 won't start. Power is ok. Condenser tank full light remains partially on even when tank is removed. When startbutton is pressed condenser full light illuminates fully. Water pours out pipe...
Pat, Have you found a solution to this yet? I have got exactly the same fault today ! Having taken the top & left side of the dryer off, I found what looks like a broken drive belt - not the main drum drivebelt which is fine, but a shorter one (about 18cm diameter loop) with no obvious place for it to have come from. Any clues would be appreciated. Dave (drdave@fsmail.net)
Dec 31, 2010 | Zanussi TC7102W Electric Dryer
The drum wont go around and it smells like its burning.
if you can turn the drum by hand it may be the motor start capacitor.fitted just above the motor if you cant turn the drum one of the drum seals will have jammed the drum the belt will have snapped as well.
Aug 06, 2010 | Zanussi TD4112W Electric Dryer
Zanussi condenser dryer stopped working - smell of burning?
sounds like you fried a heat element wire could have a lint build up problem ck and clean ventilation system if cabinet has alot of lint inside chances are that is the smell if you do not find burned wiring if alot of lint is present could have fried the thermal fuse and or limit switch
Jan 28, 2010 | Dryers
Zanussi tc 481w codenser dryer
this is possibly the belt slipping remove back panel and check the belt tention if not that it could be the bearing needs replacing
Aug 16, 2009 | Zanussi TC7114W Electric Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
