I need a reliable source for Canon parts - specifically, a separation pad for the ADF on a Canon Super G3 along with installation instructions. Thanks!!
  • tsstom Apr 29, 2010
    Thanks very much for the help.
  • 1,284 Answers
Hi, the best and most secure place you can get it from is CANON, and you can do this by contacting them on phone 1-800-OK-CANON (1-800-65-22666)..
Take care
Posted on Apr 29, 2010
Fax not going through
Check sensor flag at ADF and CLEAN the ADF roller(s) and separation pad.
Dec 18, 2013 | HEWLETT-PACKARD HP 2140 Fax
I want to download driver for super g3 printer driver
Canon printer super G3 F189402 drivers (32/64bit) can be found at driverupdate us
I hope I have helped you...
Take a look, and enjoy
Feb 08, 2012 | Canon Office Equipment & Supplies
I need part numbers for the ADF feed roller/shaft/clutch and the ADF Separation Pad/Roller.
Should be 002N02001 for the Feed Roller Assembly and 22N1487 for the Separation Pad
About $50 total for both parts
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 16, 2010 | Xerox WorkCentre M15i Laser Printer
I need parts exploded view for adf or just part numbers for all rollers in adf
FM2 - 0015 - 000 - SEPARATION ROLLER UNIT
FC5 - 0009 - 000 - ROLLER, PICK-UP
These next three part go together:
FL2 - 0006 - 000 1 PAD MOUNT UNIT
FC5 - 0042 - 000 1 PAD, RUBBER
FC5 - 0044 - 000 1 PAD, SPONGE
Aug 04, 2009 | Canon imageCLASS D880 All-In-One Laser...
The ADF takes more than one sheet at a time on the Cannon IR 5000
either something is jammed in it somewhere like a paperclip or post-it note, or the separation pad may be worn. the small rubber separation pad can be found in the hatch above the ADF, it may be possible to flip it over and continue to use it, or can be replaced easily.
The part number is FF3-3984-000
here is a photo and stockist of the part in question; http://www.precisionroller.com/doc-feeder-parts-for-canon-dadf-g1/details_20676.html
Apr 02, 2009 | Canon imageRUNNER 5000 Copier
HELP
We also have losted our manual and need to reset everything but can't rember how to do it.. Can someone please help me out on this problem. Very much appreciated!!
Jan 22, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon d660 imageclass copier
Hello himsmyboy!
Sikna says
The ADF separation pad is the cause. To remove it lift the cover fully up then use a knife to get under the black tape tab at the top right of the large white foam pad. Pull the tape and the white foam pad loose but not completely - leave the bottom attached. Now you can see the ADF separation pad from below. Use a small screwdriver or spring hook to remove the spring and you will be able to wiggle the ADF separation pad out. First take a good look at how it fits in so you can put it back! The problem is caused by the small black foam pad under the white rubbery tape on the ADF pad assembly. I carefully removed the tape from the back edge to expose the compressed black foam pad. I then cut a matching size of 1/16" foam I had in my shop which was actually HP 98A doctor blade seal foam and just stuck it on top of the old compressed foam. (other similar foam should also work) Then I replaced the white rubbery tape and rubbed the edge down well. I then reinstalled the restored ADF pad and the spring which holds it. Last I just pressed the large white foam pad back into position - being sure to pull it with a slight tension as I pressed into place. This fixed the ADF feed and it worked like new again...
Sikna out...
Jan 15, 2008 | Ricoh Aficio SP-C210SF Printer
Canon super g3
What is the model number. It seems their are several super G3 units on the market?
Oct 10, 2007 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
21 people viewed this question
k24674
jasbo
jasbo
