Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A
Chest freezer model mfco5mobw4 been plugg in for 2 days now set on the coldest setting not getting cold compressor is warm
    President:
  • 1,218 Answers
God day,
Either the refrigerant has leaked out or the compressor isn't pumping properly. If you can put your ear up to the unit and it hums that is the compressor running.
No practical repair possible unless the unit is under 5 years of age in which case you are entitled to factory warranty service.
Posted on Apr 30, 2010
I have a kenmore upright freezer and can't remember which setting it should be on. It has coldest 1 2 3 etc.
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
May 17, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
Kenmore chest freezer model 12235 - won't get cold
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 13, 2010 | Freezers
I was just given a ge chest freezer model # cb10 dk serial number vv186793. i cleaned it up and plugged it in about 5 minutes later it started buzzing . i turned the control to the lowest setting (0). and...
switch on and leave it to freeze.approx 24hours.buzzing could be compressor working overtime to get cold.or in fact the freezer is not on a level surface.
Mar 02, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Freezer not getting cold
Alissa,
Try placing two or three jugs of water in the freezer and wait 36 hrs. before opening.. If the water is frozen solid you have no problems.. if its not frozen, the call a service tech..
Jun 22, 2017 | GE 16.7 cu. ft. / 473 liter Upright...
Running High @ -10 C and should run at -20 C on coldest setting
1. Make sure the sealing gasket is making good contact all the way around. It's pretty easy to lose 10 degrees. If it is a magnetic seal on the door gasket, it may not be sealing all the way around.
2. If it is staying that cold, everything is working well enough. Maybe you need a little gas in the compressor. Time for the service guy.
By the way, is your unit speced to be that cold full of supplies? Is the door opened frequently? minus 35 is pretty cold.
Mar 11, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Not Freezing, but cold
The thermostat should be a close circuit when requesting cold temps. or when asking the compressor to come on. The exterior surface on some freezers warm when asking for cold inside. Yours has a condenser coil on the back and that should warm when cooling. If compressor is runningit should be wrm if no freon has leaked from freezer somewhere.
The defrost timer should rotate clockwise during the day and give approx. 3 defrost daily or about every 8 hours. Until the thermostat is resolved and asks for a closed circuit the compressor will not come on. Unplug freezer from outlet,remove thermostat wires, then turn the thermostat to its coldest setting and check again. If no closed circuit the thermostat will need replaced first. Hope this has helped you, Sea Breeze
Nov 01, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A Logo
326 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
