Question about Toshiba 27A43 27" TV
No sound on 3 channels - Toshiba 27A43 27" TV
  • Toshiba Master
  • 3,866 Answers
This would be a tuner issue, the tuner is loosing sound freq. and this does happend on a few channels as you stated.
The likelyhood of the station not playing audio on 3 seperate channels is neil so please consider the facts here. I would get one of those digtal external tuners from like radioshack.com to test that fact. These tv's are not digital so also consider the fact that it could be true that the audio was turned off on these standard def channels but still unlikely.
thanks this was a free solution provided by fixya.com all we ask is you leave ratings and feedback for the solution.
Posted on Apr 29, 2010
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Digital channel 25 has no sound.
First make sure SAP or nothing similar is turned on.
After you triple check that just Contact ILO if it continues for more than 1month. This is a software error.
What state are you in?
What channel is this?NBC, ABC
Have you check this at different times of day?
What TV does your son have?
Jun 24, 2009 | iLO 2600 Television
With my starview 3 all of sudden my sound is distorted
To get back sound channels ect just select the channel in question press menu,
select installation, select manual scan, click ok on down frequency.
It'll now scan for channels when its finished exit back to normal
tv viewing screen go to the end of your channel listing and the desired channel will be there with sound.
This can be done on any channel with no sound by just selecting that channel following the instructions above.
Hope this helps
Feb 25, 2009 | StarTech.com StarView SV211K 2-port KVM...
TCL LCD TV. No sound on one channel only.
I had the same problem... try toggling through the "SAP" (multilingual audio feeds) for the channel. Mine was somehow set on "audio 3 of 3" for that channel, but there were only 2 audio feeds.
Feb 24, 2009 | RCA L37WD12 37 in. LCD HDTV
Tv goes to another channel on its own
Sounds like channel 3 is not locked in. Go to menu and select add/delet channels And add 03.
Jan 18, 2009 | Mitsubishi VS-60703 60" Rear Projection...
Sound from 3 channels only
Hi, first of all did you verify with the manual if it is possible to run a testsignal through all 5 channels?
One of the most common problems in this case is the basic settings of the device. If you don't have the manual, mostly you can download them from manufacturers website. Chances are that for some reason the setting is set 3.0 stereo (also known as 3channel sound) which is always the 2 fronts and the centre speaker.
Best thing to do it is take a DVD with THX on it and run the THX setup, it will send test signal to all channels.
Jan 15, 2009 | Philips HTS3450 System
All of a sudden my Echo Indigo DJ soundcard will play both virtual CD players on my PCDJ software on one channel. For a while, I had cd 1 on one channel and cd2 on the other. I am using a pig tail plug...
I can run audio on 3 separate channels/outputs of my laptop
I use Tricerasoft Swift Elite DJ software but the areas you need to look at for troubleshooting are probably similar:
1) check the (PCDJ) software settings for selecting the channel outputs of your Indigo DJ on each deck/ player. NOTE: 1/2 and 5/6 are the same physical port (headphone port), while 3/4 and 7/8 are also shared on the Line Out port. So make sure you use for eg. one player uses 1/2, and the other player uses 3/4 ONLY IF you want them running out to separate channels on the mixer
I personally run both my decks off the same channel, ie 3/4 so that my software can do the mixing for me. My mixer only acts as an master control device where everything else connects
2) Make sure you check your IndigoDJ Console (installed to the Windows Start menu under Echo Audio, Indigo DJ), if you have any conflicts or if for some reason one particular channel pair gets inadvertently muted, resulting in no sound coming from the port.
3) I also use my onboad sound card (typically for previewing music or for an auxillary output). This is obviously controlled by the Operating system... in Windows is is through the Sound properties, default sound device. I recommend NOT using Indigo DJ as a default sound card -- but that is a personal preference.
So in this way you actually have 3 outputs for sound
As far as cabling is concerned, it depends on what you are connecting to. I use a 1/8 (mini computer) jack to 1/4 whcih then plugs into a direct box (eleminates any static hum etc), then from the DI box using an XLR cable to the mixer. Your setup may be slightly different.
Hope this helps!
Dec 01, 2008 | Echo Indigo DJ Sound Card
Channel problems
Do any of the channels produce sound?
Aug 15, 2008 | Visonik V418XT 125W x 4 Car Amp Car Audio...
No sound when recording channel 3
Is this when you are recording via CH 3 from a separate source? If so, try CH 4 or alternately, L1, L2 inputs.
Nov 13, 2007 | Panasonic PV-V4523S VHS VCR
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
Toshiba 27A43 27" TV Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
