Question about Toshiba Satellite A100-S8111TD Notebook
Laptop problems I dont know how to change my computer keyboard settings back to normal. they do the french settings highlighted in red instead of normal things like an E instead of a ?
  • Anonymous Mar 11, 2009
    didnt do anything
    Genius:
  • 3,587 Answers
Ahh..you need to go to the language options under control panel
Posted on Mar 25, 2008
SOURCE:
How can i turn off the green characters on my asus keyboard?
ust press the CTRL+SHIFT keys and you will switch from French to English
I’m happy to assist further over the phone at https://www.6ya.com/expert/sherri_bf92738d7f5863ad
Aug 23, 2014 | ASUS Computers & Internet
Change from lower case upper case
Have you tried re-installing your input device drivers such as your keyboard? Are you using PS2 keyboard ? if yes then please try to check the pins on each pair
Jul 10, 2013 | Computers & Internet
Keyboard keeps changing to control functions on the keypad instead of normal keyboard usage. We keep resetting the keyboard settings to default but keeps going back. Do you know if this is a...
High probability that this is just a keyboard key failure. Attach an Apple keyboard (or a generic keyboard) to one of your USB ports. Use it for a while. If you don't see this behavior, then the problem is in your keyboard, which is easily replaceable by an Apple tech.
Mar 30, 2010 | Apple iBook G4 Mac Notebook
My laptop keyboard hasn't been working for about 24 hours. At first, my laptop shift key seemed to be stuck because I was typing in all symbols instead of numbers like # instead of 3 or & instead of 7....
1. Boot to diags, Fn+Power see if the issue occurs in the diagnostics, If it does, you need a keyboard at a minimum. If it works normally, then it is a software setting.
2. Boot to Safe Mode F8 at boot, see if it works normally there. If not then check the regional and language settings and make sure they match the keyboard you have installed (US, UK or French Canadian Keyboard?)
Dec 28, 2009 | Dell Computers & Internet
How do I change from French keyboard?
Start / Settings / Control Panel / Regional and language options, check you have the language you want in there, then remove the additional (French) language.
This assumes you're running Windows XP. Vista or Windows 7 will be similar.
Dec 11, 2009 | Acer Aspire 4530-5889 Notebook PC
How do I shift to the blue key functions on the keyboard
I've run into this a lot myself and personally find it annoying more than useful. While typing, your punctuation keys suddenly switch to their french functions. By defaul, Vista assigns a keyboard shortcut fo changing input languages.
This shortcut is ctrl+shift - a very easy combination to press by mistake. To solve this problem, just press crtl+shift until you're back to english. You can change this shortcut or disable it all together.
Open the control panel then click "change keyboards or other input methods" under "clock, language and region". In the window that pops up, click "change keyboards..." then select the "advanced key settings" tab. This is where you can edit and disable language related shortcuts. To change one, click on the profile and then click "change key sequence". Under "switch keyboard layout", select "unassigned" to disable that shortcut.
Oct 26, 2009 | HP Pavilion dv6000z Notebook
Chose Canadin French instead of Canadian English by accident
Yes you are right: it is a one time option. You can however install other languages. You will switch from the Canadian French keyboard to the US or English Canadian keyboard by pressing Shift Alt. You will console yourself if I told you that I type mainly in French, but the physical keyboard is US and I cannot even use the Alt + Ascii code to put the accents where due, because the laptop does not have numeric pad.
Hope it helps.
Sep 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
French accent on Dell Laptop
go to the control panel - regional settings, and change your keyboard to french, mon ami:)
Jul 15, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
My daughter touches the buttons on our tv and has changed the writing for the colour brightness all of those things that are normally in english are now in something like islamic or something and I dont...
Your daughter accidently changed the language mode from English to either French or Spanish. If you push the menu button
on your remote repeatly until you see a word that resembles
"language" then highlight it and push adjust (either right or left)
you may be able to set it back to English. Some sets have a
feature that resets the adjustments back to the original settings
if the TV is unplugged from the electrical outlet for a minimum of
15 minutes then plugged back in.
Hope this helps,
Casey
Nov 27, 2008 | Televison & Video
Keyboard
that means that the keyboard has been set to a different language. On my screen at the bottom right hand is a little keyboard icon and when i click on it it lets me scroll through US English, Canadian French and Canadian Multilingual Standard. If the keyboard is set to the Canadian French option (or whatever other option that is available on your keyboard in red characters) the number two button changes function.
May 22, 2008 | Acer NSK8458AN Keyboard
Toshiba Satellite A100-S8111TD Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
