Question about Janome Memory Craft 4000 Sewing Machine
Attaching quilting foot - Janome Memory Craft 4000 Sewing Machine
    Genius:
  • 1,116 Answers
Can tell you how this works on my sewing machines that have the snap-on feet.
You have to remove the adapter for the snap-ons and then the attach the darning/quilting foot with the screw that holds the adapter to the shaft.
Posted on Apr 30, 2010
Trifect7
  • 57 Answers
SOURCE: How do I attach a walking foot
Okay let's get started.
  • First let's look at the walking foot.
  • Turn the bulky body so that it's away from you.
  • On the left you see a groove that is going to be where you attach the foot to your machine.
  • On the right is a u-shaped arm which you can move up and down. It will go over the needle clamp
Now, let's remove your present foot from the machine and look at it.
  • Loosen the foot screw until it almost comes off. (if it does come off, screw it back on a bit.) The screw is on the left of the foot-bar.
  • On the right you'll see the needle bar with a needle clamp (what you tighten when you replace a needle) on the right of the needle-bar.
Okay the walking foot business.
  • slide the walking foot into position so that the foot screw is in the slot on the right and the u-shaped arm is over the needle clamp, with the needle clamp in the middle of the u-shaped opening.
  • Tighten the foot screw securely, it's going to be under more strain than normal.
  • While you're at it, check that the needle-clamp is nice and tight as well.
Okay, then! There you go... Happy sewing.
Are you happy? Than please vote
Here are a few helpful pictures.
Posted on Mar 02, 2008
SOURCE: Singer 7430
I have a new machine. This is the second the first had the same problem so I exchanged it. It worked fine on 1 project on both machines the next the time it did the following. When sewing stich #8 which is a zig-zag stitch with a straight line on one side, I get the #8 stitch on one the bottom side and the #13 stitch on the top side. I have read the manual, also re-wound the bobbin twice re-threaded the machine twice and changed the needle none of these worked. Do you have any suggestions.
Posted on Apr 21, 2008
  • 3 Answers
SOURCE: quilting foot
My Brother Sewing Mechine Computerized is not sewing or running. What can I do?
Posted on Aug 05, 2008
bargainbox
  • 1388 Answers
SOURCE: machine quilting
Difficult to be definitive without specific model information, but......
Generally a "walking foot" will suit this best, as it grips the work on both sides and moves it all through evenly, using an ordinary style foot may mean the layers of fabric and batting shift relative to each other and bunching uneven results will occur, even with careful ststegic pinning.......speak to the dealer for your brand and quote the model you have to ask if they can supply one to suit.
As a guide, a Janome walking foot in Australi is around $AUD 65 retail
NOTE: Not all machines are able to take these feet, especially older and low end models.
www.bargainbox.com.au
Posted on Nov 13, 2008
  • 1116 Answers
SOURCE: I have a singer 6202 sewing machine and I need to
You have to unscrew the presser foot, then attach the WF, using the same screw.
Make sure the lever on the WF rests on top of the needle bar clamp.
Some WF have a two prong lever and this fits around the needle clamp like a lobster claw.
Posted on May 22, 2010
Can you use quilting bar with walying foot that came with si ger 9960
The info I found has no mention of the quilting bar for the Siinger 9960 walking foot. Most machine with that functionality include the quilting bar with the walking foot. There also needs to be a hole through the walking foot and a method to attach the bar to the foot which doesn't seem possible with what I located. However, you may be able to attach a bar or a guide of some sort using something like masking tape that can be used as a guide.
On a straight-line quilting tutorial I saw recently, the quilter laid down strips painter's tape to mark the lines on the quilt before doing any stitching. Then she simply stitched next to to painter's tape to get straight lines.
Feb 08, 2018 | Sewing Machines
How do I attach the quilting bar to the walking foot on my Simplicity Quilters Classic? The manual doesn't show how to do it
There should be a hole across the back of the walking foot (penetrates the walking foot usually from right to left, although some feet will have 2 guides--one for left to right, the other left to right) where the bar mounts and a screw to tighten and hold it in place.
Quilting Bar Attachment
Oct 06, 2016 | Simplicity Quilter's Classic SW240...
1/4 Quilting/patchwork foot w/attached shank for Pfaff #1221 available?
Check with your local Pfaff dealer for a 1/4" quilting foot. OR, search the internet for Pfaff presser foot.
Nov 10, 2015 | PfaFF Sewing Machines
Quilting and patchwork foot with attached shank
Probably, but since we don't know the model, we can't help you much.
You can search the internet for your make and model machine and search for a 1/4" presser foot. You'll most likely find one piece presser feet or even snap-on feet where you purchase the shank adapter and then separate presser feet that attach to the shank.
You can also check with your local Pfaff dealer.
Nov 08, 2015 | PfaFF Sewing Machines
How to fix squeaking Bernia walking foot?
I would oil the foot with sewing machine oil where it is attached to the fitting. Be sure to then run the foot on a scrap for awhile to remove any excess oil.
Jul 26, 2014 | Bernina Sewing Machines
How to attach quilting guide to walking foot
There is a hole in the top of the foot for the bat to go.
Apr 09, 2013 | Sewing Machines
I have just started learning how to quilt and I was told I needed a walking foot to quilt the sandwich together. I purchased one today, but I don't even know how to attach the foot. I also need to...
The foot is attached as normal, but when you're attaching it, the fork-shaped part that sticks out of the right-hand-side has to be hooked around the round pillar sticking out horizontally from the right-hand-side of the needle bar and that holds the needle securing screw. When the foot is down, you will see that the upwards motion of the needle bar raises the upper set of feed dogs on the walking foot - the whole purpose of the walking foot is to provide, effectively, a set of feed dogs on the top of the material as well as the toothed ones below the stitch plate - this allows multilayered or thick materials to be sewn as when doing quilting.
Jun 30, 2011 | Bernina Activa 130
How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
Mar 21, 2010 | Singer Sewing Machines
I hav e Bernina 1150. When I attach the walking
Hi, when you quilt straight lines using the walking foot, you need the feed dogs up, to move the fabric in a straight direction under the needle. When you do free motion quilting, which is done with a darning foot, your hands move the fabric in many different directions. Since you want to be the one to move the fabric, you put the feed dogs down and you do the work. So when you use the walking foot, keep your feed dogs up. When you use the darning foot, feed dogs down.
Feb 20, 2010 | Sewing Machines
I WOULD LIKE TO TRY MACHINE QUILTING WITH MY ROSE MACHINE. DO I NEED A SPECIAL FOOT ATTACHMENT OR COMPUTER CARD?
If you want to piece quilts, I recommend a 1/4" piecing foot. Husqvarna make several different types that may be used on the Rose.
If you want a dual feed or walking foot, check out the new Interchangeable Dual Feed foot.
You only use card with the Rose for embroidery, which you can do on a quilt, but not necessary.
Feb 04, 2010 | Husqvarna Sewing Machines
Sewing Machines Logo
157 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
