Question about Yamaha Music
YAMAHA TYROS 3, THE SOUND WILL CUT OFF IN MID PLAYING. IF I TURN OFF KEYBD AND UNPLUG,THEN PRESS START BUTTON, (CLEARING MEMORY?), THEN PLUG BACK IN AND RESTART PROBLEM IS OVERCOME. SEEMS LIKE THIS PROBLEM IS INCREASING IN FREQUENCY....LIVE IN REMOTE AREA OF PHPILIPPINES, QUITE EXPENSIVE TO GET KEYBD TO MANILA...
  • Yamaha Master
  • 5,603 Answers
I have Tyro I and II myself.
If somehow the registration is being bumped up or down during playing that would do it. VERIFY all the settings for the external pedal inputs regarding levels and function. Some of these can be set to do more than one thing. As a result, a pedal connected to the three jacks MIGHT be used for sustain and also triggering a step in registration number that is unwanted.
One needs to analyze the state of the unit when this happens...this should be possible UNLESS the whole thing including the data entry and display is freezing.
With the thousands of internal settings that are possible, it will be hard for us to give a definitive answer.
If you can afford to lose user created stuff, do a complete factory reset of the unit.
Posted on Apr 30, 2010
Testimonial: "I can only say thank you for a your -ractical suggestions, and kindness in taking the time to respond....aloha, Clay Carlton, Philippines"
Yamaha dgx 500 keyboard
Unplug and leave it unplugged for a while and then make sure the plug is nice and secure on both ends and try again
Jul 28, 2013 | Music
No sound on my SY77 yamaha synthesizer
1) Turn the power on.
2) While pressing the [VOICE] button, press and hold the [BANK D] button, then the [8] button. The SY77 will run the INITIAL TEST routine and display the Test Program Menu.
3) Press the [COPY] button. The SY77 will execute Test 48 'Factory Settings', automatically exit the test mode, and then return to play mode.
Mar 31, 2013 | Music
I want to add orchestral backing to song
Build the orchestral as a MIDI file and then merge your song and send back to the Tyros to perform it. Building on an external machine you will find is easier than trying to do it all on the Tyros.
Sep 15, 2011 | Yamaha Tyros4 61-Key Arranger Workstation...
When i plug it in to the sustain slot in my yamaha keyboard it makes the notes longer without me pressing the pedal.
You may have a pedal that is ROLAND compatible which is OPPOSITE sense from what the Yamaha requires. The Yamaha takes a NORMALLY OPEN contact.
Some Yamaha keyboards such as TYROS have a parameter that you can set to permit using either type pedal.
Some pedals have a switch to change them to use with either type keyboards.
Feb 22, 2011 | Quik-Lok Quik Lok VP-26 U Sustain Pedals
On my yamaha v50 keyboard there is another sound on the keys after the c3 key how do i turn it off to just leave the synth sound?
you must do master reset!
1) Turn on the power.
TIP: All buttons must remain depressed and be pressed in the order mentioned in step #2 for proper execution.
2) Press and hold down the [SEQ] button, then the [CARD] button (located next to the Demo button), and then the [DEMO] button.
3) Continue to hold the buttons down until the dialog box appears in the display. The display will first indicate the V50 Test Program and Main Rom Version then will automatically display the question: 'Test Entry Manual?'
4) Press the [DEMO] button. The screen will display: 'Factory Set?'
5) Press the [+1/YES] button. 'OK' will appear beneath the 'Factory Set?' readout, indicating completion of the Factory Reset, and the V50 will automatically return to Play Mode.
Jan 10, 2011 | Yamaha Music
I was looking at a 2nd hand KR 103 to buy. If while playing notes the damper pedal is pressed all sound is muted. Is there a function switch or something that needs swiching on to get it to work? The...
Please note that ROLAND equipment USUALLY uses Normally closed (electrically) damper pedals for their equipment. Most other brands use normally open ones. If you are using a non-Roland pedal, that is likely the problem.
SOME PEDALS require opening and changing a wire (involves soldering) to match the unit you are plugging into. A very few have a switch on them to allow changing polarity.
A few synths, like the Yamaha Tyros have a built in setup screen where one can select the polarity of the attached pedals.
Sep 23, 2010 | Roland Dp 2 Damper Pedal
My Tyros 2 plays additional notes when I play chords particularly in C, G and E-Flat scales. The challenge is that I am living in the Caribbean and there are nor official keyboard technicians nearby. I can...
This is not something that spare parts would likely be needed for.
The first thing to determine is if in the piano mode that the unit first comes up in do you get this problem. If you do not, the UNIT is likely OK electronically. If you DO get the problem as a plain piano at start up, then one or more disconnect diodes (small 1N4148) are probably shorted. This is VERY uncommon occurence. These diodes are on the contact boards of the keys themselves. Contamination of metal such as a paper clip or metal shard could cause the same thing.
The Tyros II has MANY features and a lot of these create layers that fire other notes when using styles as part of the stylle rhythm.
The keyboard split features that allow the keyboard to act as three seperate ones can lead one to think there is a problem.
I have two Tyros I and one Tyros II and have worked on all of them as they were purchased as damaged and non-functioning. I have schematics on CD and those are available from Yamaha America parts dept in California. They are copyrighted but they will sell you the CD with schematics, etc. for about $15.
I can help you troubleshoot the problem if it really is a problem. The first thing is to see if problem exists in the piano mode at startup. If it does, then try each note in combination to establish a pattern. If a disconnect diode is shorted, you will find certain notes interact. You need to find which are OK and which causes problems... Defining the keys as problems in chords does not help as we need key numbers such as C3 or F#4. Do the searches ONLY using two keys at a time as a matrix problem cannot be diagnosed doing three at a time or more.
Aug 01, 2010 | Music
I want to record vocal voice trhought mic on psr 9000
You could record short "samples" to be used in building new voices, however, it does NOT appear that you can record a vocal song with the PSR9000. The Tyros II and III have the capability to record vocals but the PSR9000 and Tyros I do not..
When playing back an arrangement, you can re-sing the song and have the vocal harmonizer track the arrangement.
Jul 29, 2010 | Yamaha Music
Looking for music stand that fits on top of p120
These are sold online at Kraft Music
Yamaha WB53080R Music Rest
Replacement Music Rest for P120, P140, P155, PF500, PF1000
Jun 24, 2010 | Yamaha Music
When I load a floppy with music styles into the
Not sure about your particular keyboard, but on the Yamaha Tyros the style will NOT start rhythm until you select start AND hit a chord.
The style doesn't know what chord to start with until you trigger it.
SOMETIMES the style has to be moved to a user space...
One has to read and then DECYPHIER how to work these synths... Spend a little time with the user manual, as hard as it is to understand.
Jan 12, 2010 | Yamaha Music
Music Logo
147 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
