Question about Max 2 Tail Rotor Blade For Yiboo Shark Rc Helicopter
Short flight My copter has worked perfectly until recently. The rechargeable battery in the copter seems to be going bad. After a complete charge, it will only fly about 30 seconds. I have tried charging it with the USB port as well as new batteries in the controller and charging it from the controller. There is not a model # on this copter other than Yiboo. I need help in getting a model and can I get new batteries for this? Any ideas?
4 Suggested Answers
SOURCE: right out of the box
When the controller flashes, it means that it has not paired up the signal with the helicopter. Move the accelerator control (left stick) up and down quickly several times. The rotors should start to turn signalling that they are paired. Max out the stick forward and back quickly.
Posted on Dec 28, 2010
  • 4 Answers
SOURCE: Hi, My copter crashed and
zdfbdf
Posted on Dec 31, 2010
SOURCE: My Yiboo Micro Blade Rc copter won't charge. I've
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Posted on Feb 27, 2011
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
My hercules doesnt lift. rotors turn but it spins counter clockwise uncontrollably.
i am really glad that this isnt a REAL helecopter. if you got it for christmas, you might want to return it- that is, after you verify that it is FULLY charged. this sounds like a half charged battery, that isnt spinning the bigger blades as fast as it should.
this could also be caused by any obstructions to the blades ability to rotate freely, something stuck to the blades- adding weight, bent blades, or internal belt/gear issues, regarding regulating the main blades, and the rear stabilizing blades timings.
if, before the charge, the dying battery caused the copter to crash, a blade could easily be bent, or have mud or something on it, weighing it down.
if the copter really is indestructable, i would go right back to a bad battery.
if the rechargeable battery got a memory after 4 days, i feel bad for you and your kids.
Dec 29, 2014 | Hercules Unbreakable Radio - controlled...
Rotor spins while charging
You have a bad flight control board. There may be a loose wire near 5be charge port making fontact wi5h the output circuit for the main rotors. Good luck
Feb 26, 2014 | Generic Udi u13 3 channel co-axial...
Samsung vodaphone 360 not fully charging
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 10, 2012 | Samsung Cell Phones
Rc helicopter not getting signal from remote
I think you have damaged the copters electronics when you crashed it.
Jun 27, 2017 | Toys
How do I revive a Hilti 36 volt battery from a TE6 nicdm
There is no way to revive a rechargeable battery once they go bad. Rechargeable batteries have a lifespan that is affected by how many times they have been discharged and recharged and how fully discharged they are between recharges. Most batteries will last longer if they are fully discharged before recharging and allowed to cool completely before recharging, heat being the main culprit to their longgevity. They will eventually reach a point where they will not charge anymore or if they do they will not hold a full charge for any appreciable time. The best test for the batteries ability to take a charge is to completely deplete the battery either through working it or sitting on the couch with the trigger pulled until it stops working completely, let it cool down then put it in the charger. If it charges, use it to see how long it lasts. If it dies quickly it needs to be replaced.
Dec 29, 2011 | Drills
Air hogs pocket copter, brand new. Inserted brand new batteries into charger and controller per instructions. Plug the helicopter into charger and led blinks red as stated. About two or three minutes into...
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | Toys
X107 Mini helicopter does not seem to be taking a charge from USB port on computer. ran coptor for about 2 weeks following recharging instructions... rest, recharge of heli in "off"...
Hi, My X107 MINI HELICOPTER does not receive transmit anymore. It was working fine before. It only flys if I hold the remote control right next to the sensor. If I move it away it loses transmit. Both units have full power. How do I solve this problem.
Jan 27, 2011 | Cobra Electronics Cobra RC 3 Channel Mini...
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
Short Battery Life
just today figured out that the battery supposed to be at least 17 hours and i bought it before 2 years too and even when i bought it was my battery left only for 2 hours and until today i thought it is supposed to be like that.
Jan 10, 2008 | Sony NW-A1000 MP3 Player
Max 2 Tail Rotor Blade For Yiboo Shark  Rc Helicopter Logo
141 people viewed this question
Top Max Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Max Toy Expert? Answer questions, earn points and help others
