Question about HP PSC 2410 All-In-One InkJet Printer
When I try to print, I am getting a ratcheting noise and when I open the printer on my computer it says on the line with the name of my document - 'error'. When I try to print agin, it won't go past the error docutment which I cannot seem to cancel.
  • uday_wadhera May 11, 2010
    There might be some issue in the internal printer hardware mechanism which is causing this issue. you can try following web link to resolve this issue. http://h10025.www1.hp.com/ewfrf/wc/docum... Good luck!! :)
  • 4,041 Answers
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
Pc won't accept printer via usb connection
So why won't it accept the printer? Is the printer and your operating system on the computer compatible? Did you install the printer and drivers? Are you sure the USB Port works?
Have you tried a different USB Port?
Click Start/Control Panel and look for Printers. Open it and make sure you don't have more than one instance of the printer installed. If you do, then you're confusing the computer. You can also check to see if more than one of the same printer is installed by opening a word document, then click File, then Print, and when the print window opens up click the Down Arrow on the line that shows the printer name. This will show you all other installed printers.
Mar 25, 2012 | Computers & Internet
Printer does not print from computer. Is in fax mode and I cannot get it out of the fax mode Please help
When you go to print a document and your print window opens you need to change your printer name from Fax to the printer you want to print the document.
Mar 01, 2011 | Office Equipment & Supplies
Document stuck in queue and will not delete or print.
Its a common problem. All you have to do is to restart the Print Spooler service and delete the print queue. To restart the service follow the steps: Open Control Panel > Administrative Tools > Services. Now find service named "Print Spooler" and right click over it and select "Restart" to restart the service.
Now open the "Printers and Faxes" folder and try to delete the print queue. Now you will be able to delete the print queue. If applicable you can follow the steps once again if any print queue refuse to get deleted.
Once the print queue is empty, you can print from your printer smoothly.
Cheers!
Apr 05, 2010 | Dell 926 All-In-One InkJet Printer
My printer won't print ADOBE files, but prints all word documents
I believe you are misunderstanding what you're "telling" the computer to do. You are telling the computer (I assume in Microsoft Word, but perhaps elsewhere) to generate an electronic document in PDF format. (I believe PDF stands for Portable Document Format)
It uses a printing metaphor because like a paper copy, the PDF file is designed for people to read, not edit the document you have created. Also, some PDF-making software methods involve pretending to be a printer, which allows the user to make a PDF file in any program that would normally only output your work to a printer.
Most people, when wanting to print a PDF document onto paper, open it with Adobe's Acrobat Reader (which is free software) and print the document from there. For sharing a document that you want no changes to, this is a superior option to sending people an MS Word .doc (or .docx) file, which does not have its information "locked" onto virtual pages in the file.
I hope this helped!
Jan 18, 2010 | HP DeskJet F380 All-In-One Printer
How do you clear que on a c6300 photosmart
Windows XP Operating System
Restart the Print Spooler device
  1. Open Administrative Tools.
  2. On the Windows taskbar, click Start , and then click Control Panel .
  3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
  4. Click Administrative Tools .
  5. Double-click Services .
  6. Click Print Spooler .
  7. Click Stop to stop the Print Spooler.
  8. Click Start to restart the Print Spooler.
  9. Click OK .
  10. Restart the computer.
  11. Try the print job again.
Manually clear the print queue
  1. Return to the Printers and Faxes folder that you opened in the previous steps.
  2. Right-click the name of the product, and then click Open .
  3. Click Printer , and then click Cancel All Documents .
  4. Click Yes to confirm the action.
  5. If documents remain in the print queue, restart the computer.
  6. Try printing again.
Windows Vista Operating System
  1. Return to the Printers folder that you opened earlier in this document.
If the issue continues, proceed to the next step. Restart the Print Spooler device
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
  2. Double-click Services .
  3. On the User Account Control window, click Continue .
  4. Click Print Spooler .
  5. Click Stop to stop the Print Spooler.
  6. Click Start to restart the Print Spooler.
  7. Click OK .
  8. Restart the computer.
  9. Try the print job again.
Oct 03, 2009 | HP Office Equipment & Supplies
HP PSC 1210 stopped working on a Dell desktop running Vista
Uninstall the drivers again, restart the computer, turn off antivirus, install drivers again, plug cable to another usb port when prompt, if firewall shows pop up window always choose allow or yes. Also make sure that printer is not working "off line", go to control panel, printers and faxes, right click on the printer that you want to use, check if it says "use printer off line", if it does, click on it and it will change to on line.
Sep 01, 2009 | HP PSC 1210 All-In-One InkJet Printer
When I print a document my printer prints off 3 full lines then stops and shoots the paper out, then grabs another sheet and prints 3 more lines. It does this until the document is done printing. It is...
TRY THIS
click on start button go to control panel open printers and faxes select your printer name right click on it and go to properties click on advance tab now select print processor and select WINPRINT and then RAW
now click ok and try printing
if still does the same thing then goto control panel printers and faxes and then click on add a printer select ADD A LOCAL PRINTER now select existing potr and select usb 001 click next select the brand HP and then DESKJET 990c in the printer list click next give your printer name and select set as default now click next and finish the installation now try printing
Jul 30, 2009 | HP Officejet 4315v All-In-One InkJet...
Loud ratchet noise
Have you been using ink cartridges other than store bought? Reason I'm asking is that i used a refill kit, and tried those half price refill places, only to find ink was leaking out when not in use & clogged up the ends where the cartridge moves across. take a flashlight & look at the ends of the track that the cartridges slide across on, you may see a build up of ink, that won't allow the cartridge to travel as far as it needs to go to run properly.
Nov 06, 2008 | HP LaserJet 3330 All-In-One Printer
HP PSC 2410 All-In-One InkJet Printer Logo
125 people viewed this question
Seeker5211
Seeker5211
