Question about Brinkmann 810-2300-B Grill
We are starting to use our grill after no use during the winter... the burners don't seem to be burning as strong as before.... any suggestions on what may be happening?
  • Brinkmann Master
  • 2,523 Answers
Clean the burner out then they should work better
Posted on May 17, 2010
My coleman roadtrip grill is new/unused. I followed all the directions for set up the propane tank and the burners will not light. i can't hear anything and it seems like the propane is just not...
If you don't mind turning OFF the tank vale and disconnecting the hose one more time, follow these instructions.
Starting with the tank valve Off and the hose disconnected, turn the burners on for 1 minute and then turn them OFF. Wait 4 more minutes, reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY. (Slow motion, slow). Once the valve is full open, light one burner and turn it to it's highest setting. Is the burner lit and burning? Does the flame height look correct? If so, light the remaining burner, repeating what you did with the first burner. Does this burner's flame height look correct? If so, you solved the problem.
If it didn't solve the problem, check to be sure, there's actually enough gas in the tank to sustain combustion. If that checks out alright, you have two options. 1.The grill is still under warranty, contact Coleman for repairs or replacement 2. Depending on how long ago your bought it, return it to the place of purchase for a refund or replacement. In either scenario, you will need your Proof of Purchase.
If you completed everything I suggested and the burners still aren't getting gas, it's a case of manufacturer defect. And yes, it does happen.
Good luck. I sincerely hope it all works out for you and you solve the problem.
May 12, 2011 | Coleman Roadtrip Grill LXE 9949-750
I started up the barbecue for the first time to get all of the winter crud off, and when I start it only the outside burners will flame, the middle one asks like its starting but then burns out?
Probably some of the winter crud has clogged the burner and or the venturi valve. Remove the burner, clean it and check the venturi valve for spider build-up. Wouldn't hurt to check the burner orifice too.
Apr 10, 2011 | Brinkmann Charmglow Stainless Steel LP...
The first burner seems to burn very low and not very hot
If it was me, I would,first try to clean them and see if that improves the flames. During the course of cleaning you can determine if the burners are corroded and needing replacement or just caked up and dirty. Are the burners stainless steel or cast iron? Cast iron lasts longer, and tends to get smaller in flames when it's seams corrode shut. Plus it is easier to clean. Stainless steel tends to corrode and fall apart, causing flare ups and unsafe use. Douglas
Jul 05, 2010 | Barbeques Galore Turbo STS 4-Burner...
The burners are not burning properly. The gas line seems to be clogged. Do you have any troubleshooting suggestions?
Replace the hose and regulator if this is an LP grill...... or just the regulator if this is a NG grill.
Jul 03, 2010 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Gas grill won't ignite
Yea, it sounds like it has a clogged burner or orifice. If you can remove the cooking grids, lava rocks, etc and pull out the burners, blow them out with an air compressor and make sure the orifice's holes are not plugged. You may have to use a small portable mirror to check the orifices and a small needle to poke them clean. Hope that works for you.
Douglas
Jun 12, 2010 | Char-Broil CharBroil 4637318 Grill
Gas smell when in use only.
you have a gas leak could be spilt burners needs to be fixed or new grill
May 10, 2010 | Weber Q Grill
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
I have a Patio II that is about 10 years old. The
you can order new ceramic plates from tec it is only clipped in they should be able to send instructions
Aug 10, 2009 | Tec Patio II Grill
Kenmore 4 burner grill only lights 3 burners
Looks like your regulator is not venting properly to relieve the back pressure. The best thing you can do here is replace the regulator.
May 27, 2008 | Kenmore 490 sq. in. Cooking Area Gas Grill...
Brinkmann 810-2300-B Grill Logo
66 people viewed this question
Top Brinkmann Grilling Experts
paulcarew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
