Question about GE Washing Machines
Our ge washer is putting a brown looking lint onto the clothes. what could be the cause?
  • 273 Answers
Might be a sock or other small garment that got into the pump. It does happen. Also might be something from a previous load such as a brand new towel that shed lint and stuck to the inner tub.
Has it done this more than just once or twice?
Posted on Apr 29, 2010
Why do my front load ge washer leave lint on the clothes?
A lot of build up from front loaders is caused from "scrud" excess detergent or constant cold water use. Place a cup full of Epson Salts in the machine and run through a hot wash cycle every 4 weeks or so and this will help keep bowl clean.
Dec 03, 2014 | GE Washing Machines
Why does my front load ge washer leave lint on the clothes?
We found that my family was not cleaning the kleenex and stuff out of their pokets. Once we checked all pockets very little lint appeared.
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
The problem is the wash comes out with brown flecks all over it. I have taken out the agitator and cleaned it, this hasn't changed the result, still brown flecks all over wash
WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus
detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Jun 14, 2012 | Fisher and Paykel IWL12 Top Load Washer
I get brown spots on light clothes, looks like burn marks. What is the cause for this and can it be fixed?
Look for grease in the washer, and look for lint that has gotten into the burner of the dryer. It is usually burned lint that causes this issue, correct dryer venting is the solution, after completely cleaning the unit.
Mar 06, 2011 | Dryers
Brown marks left on clothing.
You probably have significant lint buildup inside the machine. The lint gets burned by the heater and causes the dark marks on the clothes.
This could indicate a fire hazard!!
The solution is to disassemble the machine and remove all lint residue inside, especially in the heater area.
Apr 19, 2010 | Kenmore 62602 Electric Dryer
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Brown burn spots on Whites
Hot spots in the drum perhaps. Check for a loose heating element.
May 06, 2017 | Dryers
Our Performa Washer sometimes gets totally gunked up with black stuff- is there a lint filter anywhere I'm not clearing?
no lint filter on a performa washer, stay with the same detergent brand and if used same fabric softner mixing different brands will cause a gunkey compound that can get onto your clothes
Apr 17, 2008 | Washing Machines
Washing Machines Logo
55 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
