Question about Belkin (F5D7231-4) Wireless Router
Where do you find wep address - Belkin (F5D7231-4) Wireless Router
  • CIROC TECH SUPPORT
    CIROC TECH SUPPORT May 11, 2010
    since you have a Belkin your DNS should be
    http://192.168.2.1/
    after your get to the belkin router configuration site click on
    "SECURITY" which is under the Wireless section to your left
    if you have a password set on, you would have to type that in, if you
    did not put a password, then just click submit, after that works u will
    see 4 key numbers at 64-bit or 128-bit WEP your WEP should be the one
    with the green circle highlighted
  • Shawn DuRee May 11, 2010
    there is no such thing as a WEP address. There is a WEP key. Are you needing to locate the MAC address?
  • 74 Answers
You will find it in the wireless security settings on the router configuration page.
Posted on Apr 29, 2010
Where is wep key location
WEP key is in your router's configuration settings.
in windows open a command prompt (search for "cmd" from the start menu)
in command prompt type "ipconfig"
Look for "default gateway" and remember the ip address listed for it
in your browser (internet explorer, firefox, chrome) type the ip address from the default gateway into the address bar. probably something like 192.168.0.1
once you access the router settings, the WEP key is under the WIRELESS section, called security.
Aug 12, 2014 | Linksys Computers & Internet
Don't know my WEP key
Often times the WEP key is the serial number printed on your router. If that doesn't work, log into your router through your web browser (just type the router's IP address into the browser's address bar and then enter your username and password) and under Wireless Settings or Security Settings or something similar, you should be able to find the WEP key.
May 28, 2010 | Microsoft Wireless Network Adapter Xbox...
How do i find my Wep key for my netgear router
you have to access the GUI of your router. if you dont know the ip address. go to command prompt and type in ipconfig. look for the gateway ip address and type it directly to your I.E address bar. once you are inside the router interface, ussually WEP key is under wireleess security. go over there and check your WEP key. you can also change the WEP key.
Apr 03, 2010 | Computers & Internet
Cannot connect to internet error code 51330 is showing
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
Need more info? Check Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Connect connect my archos 605 with WEP address!!!
i have a 20 to 30 digit wep key and i just changed the settings to 128 bit and made it a hexadecimal wep. (hexa- ?) it should work.
May 19, 2009 | Archos 605 WiFi Digital Media Player
Wep address
WEP address is your security key to get on the wireless network. New access point usually do not have one assigned. You need to get into the router and enter it in, like a password. If you haven't setup the network, then someone else did and you need to get the WEP key from that person. If you can get it, then you could reset the router to factory defaults by pressing and holding the button in the back of the router for 30 seconds. Let the router reboot and look for a wireless network called "LINKSYS" or "DLINK" or something like that. You should be able to connect without entering a WEP key. If your computer asks you for one then leave it blank or look in the manual for the default WEP key.
Mar 28, 2009 | Linksys Wireless-G WRT54G Router
How do I get a wep key and what is it?
A wep key is a type of internet security (mostly used on routers) to prevent any unauthorized access to their internet connection. And to get a key, go to the router you wanted to connect to and ask for the wep key and to add you to their mac address book, or if you own one, go to the txt. document that was downloaded on your desktop and look at where it says network security key, and if your router has a mac address filter, add your ds's mac address to the mack address book on your router. then connect and type the key.
Nov 11, 2008 | Nintendo DS Lite Console
I am visiting my aunt, she has att broad band with wireless, I put the wep key in and it gives me limited or no connectivity. It gave me a 168 address so I manually put in a 192 address, got rid of limited...
First take off WEP.
Next, ensure DHCP is enabled on router.
Don't set a manual IP address in computer, it should auto detect.
You probably have the WEP key wrong
Use the HEX WEP key in windows, do not use a pass phrase.
Aug 17, 2008 | Computers & Internet
Wep address
Your wep adress? You mean your IP adress? Go to http://whatismyip.com/ and that number is your IP adress. Enter that manually, and your XBox should be connected.
Jul 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Got connected, but no recieved data
Firstly don't encrypt your connection until it is up and running. Depending on your router, if you require it to allocate IP addresses automatically you have to make sure enable DHCP is ticked, otherwise see what the IP address of the router is e.g 192.168.2.1 and set your network TCP/IP properties to 192.168.2.2 or any last digit as long as it is not the same. This is the router IP address and not your ISP address. Lastly set up your encryption but there are two ways of sharing the connection, one is called a 'wep shared key'; the other 'wep open' so make sur your pc wireless network is sharing the same type of WEP. Hope this helps Please rate this solution.
Nov 08, 2006 | NetGear MA101 802.11b Wireless Adapter
Belkin (F5D7231-4) Wireless Router Logo
32 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
