Question about HP Officejet 4110 All-In-One InkJet Printer
Scanner image of document is not type but small blocks of black & gray.
  • 4,041 Answers
Hi there
If you have your CD for yuor printer, then just add and remove the old printer driver in your PC close down and restart the PC then put back your printer driver.
All the best Pineworks
Posted on Apr 29, 2010
EPSON XP400 SCANNED IMAGE FADED B&W OR COLOR
try to reinstall drivers or try to scan connected to other pc, if problem remains, scanner is done
Feb 02, 2015 | Epson Office Equipment & Supplies
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
Konica Minolta Bizhub C552 is counting Grayscale pages as color.
I changed my image/graphic into a bw bitmap image. It worked for me. I get charged one side color and the other side bw.
Aug 21, 2012 | Konica Minolta Bizhub C552 Color Printer /...
Want to print black and white. How?
Setting the font type color in a Microsoft Office Word document to black will ensure that the document prints the text in black. However, if there are images, graphics or photographs within the document, they will more than likely print in color or hued colors similar to black. To ensure that the entire document prints solely in black ink, you must set the color settings on your individual printer to black-and-white
Instructions:
1.Click "File" and then "Print." To open the print dialogue box using keyboard commands, press "CTRL" and "P" simultaneously.
2.Select the printer you are using at the top of the dialogue box under "Printer" and "Name."
3.Click the "Properties" button next to the selected printer. The dialogue box that appears is different for all users, as it depends on the type of printer being used.
4.Click on a tab, button or selection box indicating "Color." Most options include high-quality color, grayscale and black cartridge only. Choosing grayscale will print the document using various shades of gray and other tones such as blue or green that match the actual hues in the document visible on the screen. A photo or picture that may look black or gray could actually have blue undertones. To print purely in black and white with no undertones, you must select either "black cartridge" or "black and white only."
5.Select "OK" to return to the Microsoft Word printer dialogue box. Press the "Print" button to print the black-and-white document.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Computers & Internet
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    Where is the scanner lock switch on the mx850
    You need to lift the document cover, and you should see a small gray slide type switch on the top of the printer's scanner, near the front left corner of the glass. Slide the switch to the unlock position, close the document cover, then turn off the machine. Wait 5 seconds, then turn the machine back on. This should restore the scanner function.
    Dec 19, 2010 | Canon PIXMA MP830 All-In-One InkJet...
    Out going fax is coming black
    FIRST test copying. if the copy come out completely black, then the exposure or scanner lamp or contact image sensor is dead,not lighting on. Now if the copy has black only black lines on it,then you can clean the place where the document passes thru where the light of the exposure lamp projects unto the text of the document being scan,which is the small glass on the left side of the platen glass when you open the auto document feeder.NOTE: Lay your document on top of the platen glass & make copy if the copy come out clean as you needed it,then the lamp is O.K. Then the small glass just need to be clean. If the copy is completely "BLACK", then the lamp is dead, or the circuit that control it. In thus case then you need a technician to do it
    Jul 14, 2009 | Panasonic KX-MB781 All-In-One Laser...
    Scanning slides produces black images. Slide
    Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
    Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
    Faulty scanned images
    Pls check your color Scan settings. Generally there will be some color difference between the original and scanned Image because, the original is 'reflected light' whereas, the scanned image is a 'source light' on the monitor. The monitor setting can also affect the color output. S. Mohan
    Jan 28, 2009 | HP ScanJet 2400 Flatbed Scanner
    Scanned image appears to have an exposure problem
    Are you using the software from HP? It sucks. Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away!!!!
    Jan 10, 2009 | HP ScanJet 5300C Flatbed Scanner
    HP Officejet 4110 All-In-One InkJet Printer Logo
    23 people viewed this question
    Seeker5211
    Seeker5211
