Question about Kenwood DDX-512 Car DVD Player
How do I disable the parking brake safety feature on a jensen VM8113 car dvd player?
  • yadayada
    yadayada May 11, 2010
    this is a hazard and will not supply any instructions.
I have this exact same unit, here's what you do:
1) Cut the little weird "do-hickey" off the end of the pink wire so that the wire looks like all the other wires.
2) Strip some of the coating from around the tip of the wire (so the wire is exposed).
3) Ground that wire to the unit itself under one of the clips or something (as long as its metal).
4) Pop a dvd in and it will play irregardless of the parking brake position.
5) This definitely works, however, I'm assuming this is so your family can watch and not you, right?
Posted on Jun 07, 2010
    Scholar:
  • 84 Answers
Never done it on that particular model but, have you tried hooking the parking brake wire (coming out of the unit) to ground and running a switch to it? The way it usually will work, when the screen appear telling you to put in in park just flip the switch on for a few second the off for a few seconds then back on again. Sometime just grounding it works.
Posted on Apr 29, 2010
I bought the jensen vm8113 for the dvd player. I travel a lot with my family and thought that the dvd player would keep my passengers occupied while i drive. Problem once i installed it, i found out that...
To be honest with you, it's a very easy fix. If you read the install manual it shows the parking brake needs a negative (-) to function. In theory you hook this to the parking brake and when it's applied it will sent a negative to the attached wire, thus activating the playback. Just attach this wire to the negative ground on the system or wire a switch and install it in dash. With 1 wire going to the parking brake wire on the cd and the other going to the ground so you can de-activate it when you wish.
Sep 03, 2010 | Jensen Car Audio & Video
Is there anyways to override the parking brake line on a jensen vm8113
g brake line is just an earth, its a safety precaution so you dont watch and crash, if you want to have it play while you drive simply earth that wire somewhere else. connect it to the earth on your dvd player itself that will trick the system into thinking the park brake is up.hope this helps and please drive carefully :p
Jun 21, 2010 | Audiovox JENSEN VM8012 3" WIDESCREEN...
How to disable the parking brake sensor on lx470
simply hook it to a togle switch. Hook one end of the switch to ground, hook the other end to the jensen, then you can flip the switch off and on to make the jesen think you are using the parking brake
Aug 16, 2009 | Jensen VM9510 Car DVD Player
Question jensen vm 9512 put in pat code still getting cannot wash wille driving
You cannot watch while driving as it's a safety feature of in-car dvd players, to by pass, disconnect from handbrake/parking brake switch.(found at the base of handbrake/parking brake). But doing so makes the use illegal in most countries not to mention dangerous.
Jun 16, 2009 | Audiovox VM9512 Car DVD Player
Keep getting emergency brake screen
There is a connection that's supposed to be made to the e-brake swirch so that you can not watch movies while the car is moving. It disables the video unless the park brake is on for safety. To bypass this, that connection (that's supossed to go to the ebrake switch...(see your manual) needs to be permanently tied to ground. This will make it work anytime, and eliminate the screen you are seeing.
Jun 11, 2009 | Jensen VM9410 Car DVD Player
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
How do i bypass parkingbreak for a jensen 9311ts on mustang 99
take the parking brake wire should be pink or some funky color and hook it up to a +12 power source.
that way there is no need to use the e brake or anything for it to work
But as a word of caution all this is illegal in most states due to people not keeping their eyes on the road. ive read of people getting tickets for having disabled this security feature on their stereos. some insurance companys will not cover you if there's an accident you are involved in and you by-passed the safety feature. so before you do it, be sure to read your local laws and check with your insurance agent before doing it. you will not be happy finding things out the hard way.
Dec 02, 2008 | Audiovox VM9311TS
Jensen uv8
Yes, most of them have a factory bypass that you can enable, though this is illegal because you can not legally have a movie in front of you while you are driving. There are people that will insert the code for you for about $50, or you can find the code and do it yourself. I was able to disable it myself on my Jensen.
Nov 27, 2007 | Televison & Video
Kenwood DDX-512 Car DVD Player Logo
1,023 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
