Question about Troy Bilt Tb70ss Gas Trimmer
My tb70ss will start and run for 2 to 3 minutes and then stops. It also smoke fairly heavly. Any idea why it will only run for a few minutes? Matt
  • 3,740 Answers
Hi Matt and welcome to FixYa. I am Kelly.
Often when an engine only runs for a few minutes there is a restriction in the fuel supply or it is getting air into the system.
This little bugger is the biggest reason they draw air:
http://www.ereplacementparts.com/primer-and-hose-assembly-pi-282388.html?osCsid=1nn68dg2edk4v9o8lkr05c01j5
Check the hose for cracks / leaks and the bulb for pin holes. If your seeing air in the bulb as you depress and let go of the bulb you can be sure there is a problem in the hose or bulb.
Other sources for restrictions can be the outlet in
the bottom of the fuel tank, or a pinched hose.
The smoke is a result of the fuel mixture have a tad bit too much oil in it. That should not be a major concern at this point. It can eventually fowl the spark plug.
Your parts can be found here:
http://images.google.com/imgres?imgurl=http://www.ereplacementparts.com/images/mtd/TB70SS_(41CDT70C966)_WW_1.gif&imgrefurl=http://www.ereplacementparts.com/troybilt-tb70ss-41cdt70c966-trimmer-parts-c-26780_27267_27466.html&usg=__9rYYLlYdGqyBZHiwd1INaGkXhU8=&h=764&w=590&sz=22&hl=en&start=1&um=1&itbs=1&tbnid=-gNDJFORNOLfVM:&tbnh=142&tbnw=110&prev=/images%3Fq%3DTroy-bilt%2BTB70%2B%2522Engine%2522%26um%3D1%26hl%3Den%26sa%3DN%26rls%3Dcom.microsoft:en-ph%26tbs%3Disch:1
Thanks for using FixYa.
Kelly
Posted on Apr 29, 2010
Diesel engine runs then stops then runs stops every few minutes
Mate I use to drive a freightliner and it cut out on me one day, I eventually got it started but cut out again after about 5 minutes, I rang a mechanic to come out and he found a heat sensor wire came off the radiator and that caused the motor to cut out... Hope I haven't wasted your time.......
Mar 09, 2016 | 2007 Chrysler Grand Voyager
Will stop running when the triger is pulled
Most 2 cycle engines have 3 choke setting. Place it in 1 and pull until I starts then it will die. Then place in 2 and pull again. It should start and run a little rough for a few seconds. Once it is running flip it to 3 and go. If it still dies when you give it gas try running in the #2 position. The problem is the air/fuel mixture is too high. Locate the screw on the carb and turn to the left to reduce the amount of gas. Hope this helps
May 06, 2012 | Troy Bilt Tb70ss Gas Trimmer
516 Cdi sprinter sudden blue smoking for few minutes and after OK
somthing in the ignition is causing a weak spark--or fuel inject circuit is running to rich----------all causes improper burning---------get a computer diagnostic done
Apr 07, 2012 | Cars & Trucks
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
My Troy-Bilt TB70SS starts fine,but it will only rotate the spool if it`s in half choke.If i put it on run it stops rotating.
Hey... I have the same problem. It will start if I put in on #1, then it will continue to run if I put it on #2... but will eventually stop. It likes to idle between #1 and #2... but it will not run full power on any speed. Relativey brand new. Piece of junk and I will never buy a Troy Built anything even again!
Sorry I could not help with your problem. I can usually fix anything, but this thing is a piece of ****!
May 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Smoke from engine of lawnmower
usually large clouds of smoke are from having too much oil in the crankcase, or tipping the mower so that oil runs into the cylinder. Check the level of oil, and make sure it's not overfilled.
Mar 26, 2010 | Pool & Spa
Weed wacker runs then quits and won't start for hours
Sounds as if the issue is related to heat. Possible ignition failure when hot. (I see that alot in my shop.) If the unit is new take it to an AUTHORIZED repair shop and it should cost you nothing. Locate your nearest repair shop HERE.
Hope this is helpful,
Dolf-
Oct 18, 2009 | Troy Bilt Tb70ss Gas Trimmer
New TB70SS used one hour run great started easy. Following week started on run fine for 10 minutes it became sluggish and died. Has not started since. Yes new gas correct mix. check spark arrester for...
If the trimmer is new and giving you these problems, then take it back to the retailer and either trade for another one, or pay a little extra for a 4 cycle. The 4 cycle is a little hard to start too, but will run out perfectly and no more mixing of oil.
The higher price tag is well worth the time, effort and aggrivation experienced versus a 2 cycle engine.
I hope this helps.
Jul 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Smoke problem
hey
there are couple of smoke type.blue smoke is oil, black smoke is fuel, and white smoke is water, if it clears after starting and running a few minutes it's probably your valve guide seals leaking oil down on top of your pistons, causing it to smoke until burned off and foul your plugs.
Jun 28, 2008 | Peugeot Liberte Cars & Trucks
Troy Bilt Tb70ss Gas Trimmer Logo
341 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
